Need wiring answer 2013 Tacoma TRD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brighteyes5423, Mar 27, 2018.
  1. Mar 27, 2018 at 6:15 PM
    brighteyes5423
    brighteyes5423 [OP] Member
    2013 Tacaoma trd
    So that connector was left hanging, and now that everything is back together, the fog lights aren't working. Considering all that could have gone wrong, this is simple and shall be fixed another day. Now onto the temp gauge reading hot...hopefully just a system burp will do, if not may need a thermostat. Wont be able to check this issue til Friday. So appreciate everyone's help today.
    UPDATE: burp worked, added a bit more coolant and we are in business. Friday is getting AC charged and that pesky fog light issue. :yay:
  2. Mar 27, 2018 at 7:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  3. Mar 28, 2018 at 5:52 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    In the File link I posted - with MY pdf reader shows around page 281 and 282 is the fog light section. I do not see a 14 pin connector in diagram for fog lights. I suggest you trace the fog light issue from the battery to the lights . IT might be that this is an un used connector as previously mentioned.
    Great job with the repair.
    Also, I think you should patent a 2" x 6" magnet sign that says "You can Do It!" - I'm sure all the mechanics would like to put one on the inside lid of their tool box.
    brighteyes5423[OP] likes this.
  4. Mar 30, 2018 at 11:26 AM
    brighteyes5423
    2013 Tacaoma trd
    Ok yall, help please. Everything is connected, except the one I already questioned that has no place...
    Anyways, my problem now is the backup camera on mirror, the hands free microphone, and outside temperature do not work. Ugh...
  5. Mar 30, 2018 at 12:41 PM
    Canufixit
    New England
    I scanned at least the first 40 pages of the schematic / link I posted..... IT appears that the Overhead mirror and etc. gets routed to the radio. Per your previous message " As with the radio, not every hole gets a plugged connector. I do have 2 I think left hanging, but I remembered that." I'd recheck these connectors first.
    SteveC
    update - scan through the first dozen or so pages in the schematics and especially look at the top page descriptions and you can see .....
  6. Mar 30, 2018 at 12:43 PM
    brighteyes5423
    2013 Tacaoma trd
    Thanks Steve, actually there are more holes than plugs, lol. Either way, that' not it.The compass works but nothing else on mirror. Navigation not working, you hear it audible but no visual on screen. Mic also still not functioning. All dash removed, and every thing rechecked, grounds, connectors, etc
  7. Mar 30, 2018 at 12:46 PM
    Canufixit
    New England
    is it possible you have a plug in the wrong location ???? And, it may be possible to force a smaller connector into a larger hole ....
  8. Mar 30, 2018 at 12:47 PM
    brighteyes5423
    2013 Tacaoma trd
    no, each connector is color coordinated or has specific clips that are different than rest in the group or on the item in which they connect.
  9. Mar 30, 2018 at 12:51 PM
    brighteyes5423
    2013 Tacaoma trd
  10. Mar 30, 2018 at 12:57 PM
    Canufixit
    New England
    Do you have steering wheel controls in the steering wheel ??? If so, do they all work correctly ? (Radio volume, mute buttons, on/off hook switches for the phone?
  11. Mar 30, 2018 at 12:59 PM
    Canufixit
    New England
    don't give in .... just take a break. After all "You can Fix it !"
  12. Mar 30, 2018 at 1:15 PM
    brighteyes5423
    2013 Tacaoma trd
    steering wheel controls work. Haha, yes the ol' tape message
  13. Mar 30, 2018 at 2:10 PM
    brighteyes5423
    2013 Tacaoma trd
    ok, the original post about a connector... well, 2 connectors had to be reversed. there's still one in attached but it's now the correct one. :taco: Thank you everyone!!
