Need wiring/electrical advice.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Junkhead, Jan 25, 2022.
  1. Jan 26, 2022 at 11:17 AM
    Junkhead
    Junkhead [OP] TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Really appreciate the info guys. When I’ll get home from work I’ll look into it some more.
    I do think switch in cab would be the best. I also am planning to install winch this summer, so I will need to plan ahead for that as well.
    Kyle_[QUOTED] likes this.
  2. Jan 26, 2022 at 11:19 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    One possibility you might consider, the DSIM rock light kit. Comes with relay and mostly plug and play, just might need to extend the wire a bit to reach your spot. Pretty simple and pretty clean, if you're willing to treat these as aux cargo lighting. Assuming the rack blocks the OEM cargo light, having it on together with these shouldn't be a major bummer. If it doesn't block then all the better, more lights all pointed the same way.
    Junkhead[OP] likes this.
  3. Jan 26, 2022 at 12:00 PM
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    https://www.amazon.com/gp/product/B076C4MXR1?ie=UTF8
    I just picked up one of these harnesses for an LED grill I'll be installing soon and it would work for yours as well since it's dual leg for 2 lights. Comes with relay and switch, and the switch could easily be cut off and spliced to a factory style switch mounted in your dash. Only issue you might run into with the location of your lights is the need to splice in a few longer wires. Make sure to use environmental splices and/or shrink wrap to prevent shorting, especially on any splices outside the cab.
  4. Jan 26, 2022 at 12:14 PM
    huskcummerbund
    huskcummerbund Well-Known Member
    2020 TRD-OR MT
    I totally get the desire for an OEM style switch, but you may consider getting an On-Off-(ON) rocker switch. I bought one for the lightbar on my Mazda3 before it got wrapped around a Nissan. The (ON) side is momentary but you can wire both sides together for the same device. The result is the ability to blink or flash the lights for a moment without clicking them fully on. While illegal to do, would be handy idiots driving around at night with just DRLs that didn't get the hint when you were behind them turning your lights on and off, or as a less dick move option than brake-checking a tailgater. I'm trying to find an OEM style rocker that will do that but I think I'm going to have to order something custom or modify something.
    Junkhead[QUOTED][OP] likes this.
  5. Jan 27, 2022 at 8:37 AM
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    Hmm there are a lot of stupid tailgaters here, might not be such a bad idea after all, haha.
    Decisions, decisions…
  6. Jan 27, 2022 at 8:40 AM
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    Hopefully this weekend I’ll come up with a plan. Thanks for all the helpful replies.
    huskcummerbund likes this.
  7. Jan 27, 2022 at 8:52 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    This is possible.
    You need two relays. One needs to be DPDT to act as an intermediary to cut out the back up lights (if you care) when you run the manual override. Even so this can lead to accidentally cutouts if you leave the manual on.
    I have a similar setup but used the cab bed light circuit instead. I can operate the pods as On-Door-Off. Very convenient. Write up in my build thread.
    I have separate low profile pods for backup as well integrated into the backup circuit but point to the ground side to keep them street legal. Also in my threads.
    I’ll post some below.
  8. Jan 27, 2022 at 8:55 AM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    • Scene lights (Meso ScenePods):
      • I mounted rock lights and grooveTEKs after painting (red matches other parts). Very easy, cut out the cut outs in the Armor, set and drill a 9/32nds screw hole for the provided pan head screws and gently but firmly push screw in the grooveTEK in essence self tapping the Armor. I choose to pre-mount the rock-light in the housing but it makes no difference.
        For wiring, I wanted to be able to activate these scene lights [the Rock-lights in the GrooveTEKs] from the cargo lamp switch/door switches, so I tapped into the cargo light cable. You do not need to do the whole headliner removal, just the rear to need to gain access to the Cargo-Lamp cable.
        1. With a small panel removal tool or carefully with a small flat head, pop off the hanger hook lower cap, then pinch off the hook clip and remove the rear hanger hooks. This gives you enough headliner slack to access and locate the split tube conduit leading to the cargo light.
        2. Carefully trim the two tape mounts and release to expose.
        3. Tap the: Green (+)-Cargo-Lamp) and White/Purple (-), - ignore the Purple (+Brake) to drive your relay. I fished my lines down the driver's C-Pillar to my wiring junction (relay/power) connections that lead to the power side of the scene lights. More on that elsewhere in my build.
  9. Jan 27, 2022 at 8:56 AM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    • Rear backup lights: (KC C3s) under the rear bumper switched with reverse. The bracket came with the C3s, the frame mount hole either existed or I used the stock bolt, I don't recall, but I did not have to drill or fab anything. To wire, I popped out one of the reverse light bulbs (as if changing the bulb), put a meter on the socket to find the (+) lead and then tapped it for the relay. After testing it all out I taped and tucked all the wires with tie-wraps/splice tape and split coil. These things take a beating behind the rear wheels so I went with high quality everything and mounted them closer to center. As "rear facing low angle headlights" they make backwards driving child's play in any conditions and I wipe them off every time I wipe off the backup camera.
  10. Jan 27, 2022 at 9:17 AM
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    Awesome write up man, thank you. I’ll definitely give it a thorough read when I get home.
  11. Jan 27, 2022 at 9:33 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
