Need Your Help Installing My RETROS! Wiring? <Pics Inside>
Discussion in 'Lighting' started by RAD, Aug 23, 2010.
  1. Aug 23, 2010 at 10:37 AM
    RAD
    RAD [OP] Well-Known Member Vendor
    Rad
    LAX & LOGAN
    So I've been getting help from some of the guys but I'm still stuck and not 100%.
    So I've laid everything out the best I can and want to understand it 100% before I attempt it. Its the <OCD> in me or me just being an Idiot. LOL. I can install HID PnP Kits with no issues. This is a little too much for me.
    Test Fit
    Below
    Ok. I'm going to Number Them from Left to Right.
    Let me know if I'm right.
    1. Thats the Passenger Side! Whoot
    I connect the Black & Red Wire to the Bulb Wires?
    2. That goes into the OEM Driver Side Connection! Whoot
    3. Thats the Driver Side Connection.
    4. Thats where I need to Ground it to Metal. (Where)
    1. Red Goes to the Bulb. I trim the OEM Black Rubber Seal
    2. Black Adapter goes to the ballast kit (Plug into one another)
    < OK this is where I need most my Help >
    1. The two Metal Wires are coming from my Headlights (Top Left Corner)
    2. Do I connect the Red & Black wire to them? Then Electric Tape them off?
    3. The Black lonely wire is where I ground it to metal
    This is repeated on the other light?
    THANKS IN ADVANCE:D
    Any other Guides, Feedback, Pointers, Help is all Welcomed!
    I searched everyones thread and they only have pictures of putting it together. Not the wiring part.
  2. Aug 23, 2010 at 10:42 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    the two wires coming from your headlights are for the shutter solenoid so you connect them to the respective wires that come with your kit, and ground the lonely black wire to your frame. Red to Red, black to black.
  3. Aug 23, 2010 at 10:43 AM
    RAD
    Rad
    LAX & LOGAN
    I don't have any wires that connect to the metal wires coming out from my headlights. . .
    This is where I'm lost.
    So in the picture those wires don't go to one another.
    (Everything that came with the kit is in the picture shown)
    Am I missing something?:confused:
    Only thing not pictured is some mounting hardware for the ballast, stickers, and the other Ballast.
  4. Aug 23, 2010 at 10:45 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    the two wires that come out of your headlights should connect to the black and red wires shown coming out of the harness
  5. Aug 23, 2010 at 10:48 AM
    RAD
    Rad
    LAX & LOGAN
    So i just connect them together.
    Doesn't matter which one right? the wires coming out of the headlights are both RED.
    1. Connect one Black to the Red Wire.
    2. Connect one Red to the Red Wire.
    3. Electric Tape it to secure.
    4. Repeat steps on other light. Call it a Day?
  6. Aug 23, 2010 at 10:50 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    that's weird that both wires coming out are red, mine where different colors, but yea, just connect one of the red to the harness red, then the other red to the harness black, but dont tape them up cuz u wanna test them to see if it works. if it doesnt work, then switch them up
  7. Aug 23, 2010 at 10:53 AM
    RAD
    Rad
    LAX & LOGAN
    Thats what really threw me off! I sat there going.. Am I missing something. Then AZOGSS was telling me to connect the red to the red, black to the black. I said. I have none of that and sat there stumped!
    Thanks Aaron and Thanks AZOGSS! :p
  8. Aug 23, 2010 at 11:01 AM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    :popcorn: subbed for when I wire mine up
  9. Aug 23, 2010 at 11:16 AM
    RAD
    Rad
    LAX & LOGAN
    ^ This will help out a lot and when I'm done. I'm going to show better pics and how to....
    Where is the best place to Mount these BALLAST?
    I don't like the idea of them mounted onto the Headlights itself.
    Anyone have pics or suggestions. I'd like a secure/clean placement for them!
  10. Aug 23, 2010 at 11:17 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    I mounted mine next to the radiator cross member where there were random bolt holes.
  11. Aug 23, 2010 at 11:21 AM
    RAD
    Rad
    LAX & LOGAN
    ^ I'm going to search for existing bolt holes and whore them out. :p
  12. Aug 23, 2010 at 11:27 AM
    STR8_BEAST
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    you could mount them where the stock ballast is under the headlight, or atleast i think its the stock ballast :notsure:
  13. Aug 23, 2010 at 11:35 AM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    yeah, the red and black wires are there to wire up your high beam ability in your fx-r lights.
  14. Aug 23, 2010 at 6:08 PM
    RAD
    Rad
    LAX & LOGAN
    So everything is complete and in. I have all 3 wires that needed to be Grounded, Grounded.
    I plugged both Ballast into all the wires that needed to be. . .
    They DON'T come on at all. I dont hear the Ballast turning on like the Fog Light Ballast do.
    I'm Lost @ the moment and can't figure it out.
    You see the metal Prongs on these. . . Do I need to crimp them into one another to get it going?
    I dont hear the Ballast going on. . .
  15. Aug 23, 2010 at 7:45 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Those wires are for the shield solenoid. The bulbs should at least come on... Stupid question but you put on the D2S adapter and turned it right? If the ballasts are on, then they are obviously getting power, but not your bulbs.
  16. Aug 23, 2010 at 8:17 PM
    IamTacO
    adam
    QC az
    i had an issue not too long ago where the bulb wasn't making contact with the two wires on the inside of the socket. the light would not come on then either.
  17. Aug 23, 2010 at 8:32 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    Get a 12 volt test light to check all of the connections are hot.
  18. Aug 23, 2010 at 9:11 PM
    RAD
    Rad
    LAX & LOGAN
    Thanks Guys!
    I didnt have the Bulbs fully screwed in and didn't turn them correctly. I also did something else dumb! :rolleyes:
    Thanks to Aaron (BlackHawke88) for the help and Enjoy My DUMPLINGS Sucka!
    They are freaking INSANE!
    Thanks to YOSH also.
    He aimed and mounted them perfectly. It sits so level!
    ***DROOOOOOLING**
    Ty - You were so right. Just wow.
  19. Aug 23, 2010 at 9:33 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    So I was right? :D
  20. Aug 23, 2010 at 9:43 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    your dumplings were so juicy in my mouth
