Needing advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacosalt, Apr 18, 2020.
  1. Apr 18, 2020 at 12:37 PM
    Tacosalt
    Tacosalt [OP] New Member
    Justin
    2013 trd sport
    Hey tacoworld thanks for the add, I'm needing advice from some gurus figuring out this vibration.
    I have a 2013 Trd sport, I have recently replaced all shocks with bilstein 5100s. The front is set on the 1.75 setting with stock coils and 1in blocks in the rear. I have done the ecgs bushing upgrade, ome carrier bearing drop and diff drop. I replaced my carrier bearing with Toyota OEM part along with the ujoints. The tires I am running are atw3 275 17 that have been balanced and a front end alignment has been done after all the front end work. I am feeling a vibration in the seat at about 30mph and slowly fades at about 55. Not sure at this point what the culprit could be. Please help
  2. Apr 18, 2020 at 12:41 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Do your rear blocks have an built in angle? Rule of thumb is 1 degree angle per inch of rear lift.
    Tacosalt[OP] likes this.
  3. Apr 18, 2020 at 12:43 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Remove the diff drop for 1 as it's not needed on 2nd gens, Does it go away in 4wd? And who did the U Bolt work?
  4. Apr 18, 2020 at 12:45 PM
    Tacosalt
    Justin
    2013 trd sport
    Yes they do have a slight angle built in
  5. Apr 18, 2020 at 12:47 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Carrier bearing shim could help as well. Throw a washer on as a temp to see if that helps.
  6. Apr 18, 2020 at 12:48 PM
    Tacosalt
    Justin
    2013 trd sport
    I did all the work myself. No it doesn't go away in 4wd. I'll remove the diff drop and see if it improves.
  7. Apr 18, 2020 at 12:50 PM
    Tacosalt
    Justin
    2013 trd sport
    I have the old man emu spacer kit installed right now. Think it might be too much?
