Needing Help!!! Engine is cutting out and missing like crazy!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kuneff, Mar 22, 2011.
  1. Mar 22, 2011 at 9:32 AM
    Kuneff
    Kuneff [OP] Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    97 Tacoma 4cyl, 5 speed, 4x4.
    I have been trying for days now to take notes on the consistency of this miss.
    It is a Part Throttle miss. It never misses at idle and has yet to miss at Wide Open Throttle. Its consistently Part throttle, uphill with a load, downhill with no load. It misses when the engine is cold and at operating temp. It misses in the rain as well as dry. No climate makes it miss more or less. Speed is not a factor either. The truck is NOT throwing a check engine code.
    Now this miss is best described as this.... Drive down the road at whatever speed. 5mph to 85 mph. Reach up and click the ignition key off then right back on... Thats what I am dealing with. The only difference is when I click the key, my gauges drop and warning lights come on. The miss does not alter any of that stuff.
    This will last from a fraction of a second to a couple seconds. A few times not I had to push the clutch in and start the truck again. In those cases it fires right back up and takes off time. Its not hesitating like it running out of fuel. It runs fine then out of nowhere it misses. On my 47 miles each way drive to work it will do this anywhere from 10 to 50 times.
    Now, things I have changed helping to narrow it down....
    Now fuel tank (old one was rusty anyhow)
    New fuel pump/gauge unit
    New fuel filler neck
    New gas cap
    New fuel pump
    New fuel pressure valve on fuel rail
    New fuel pump relay
    New used fuel pump wiring harness
    New plugs
    new wires
    new coil packs
    New ignition switch
    I am drawing a BLANK!!!!!! Can anyone give me some insight????
  2. Mar 22, 2011 at 9:40 AM
    dustinclm
    dustinclm Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    alternator or vacuum leak or injectors....???
  3. Mar 22, 2011 at 9:48 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I was wondering about injectors as well.... but they are ALL cutting out. its just like clicking the key off and back on.
    Alternator is making juice right, new battery.
    I have looked for vacuum leaks, but I have not found any. You can not hear any air hissing anywhere under the hood.
  4. Mar 22, 2011 at 9:52 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Circuit opening relay? (might be same as fuel pump relay)
    EFI relay?
  5. Mar 22, 2011 at 10:12 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    The relay I changed is the one under the dash (near steering column) that the shop manual said was the fuel pump relay.
    Would that be different from the EFI relay? Where is the EFI Relay? fuse box under the hood? Any idea how to test it?
  6. Mar 22, 2011 at 10:24 AM
    RKTaco
    RKTaco Member
    Royce
    Rochester, NY
    07' Dlcb 4x4 Sport Silverstreak
    Weathertechs
    Check all your grounding wires, bad grounds can make for intermittent problems.
    Did you scan it or are you just going by the fact the light isn't on? There are some codes that won't show the light right away.
    From all that you have already done, symptoms point to a vacuum leak, possibly the throttle body/intake manifold gasket.
  7. Mar 22, 2011 at 10:42 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I have a nice OBD I & II scanner. It brings up no codes, nor is the light on.
    I rebuilt this truck from parts. Would you happen to know where all the grounds are? Maybe I am missing one? The truck was not missing like this in the beginning when I started driving it.
    I have tried the spray test on the intake and the trucks idle does not change.
  8. Mar 22, 2011 at 10:50 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yes EFI should be under the hood in that fuse box. You should have continuity between 85 and 86. No continuity between 87 and 30. Battery voltage across 85 and 86 will give you continuity on 87 and 30.
    Just out of curiosity, what is the RPM that this happens at?
  9. Mar 22, 2011 at 10:54 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    spray test??
  10. Mar 22, 2011 at 11:05 AM
    Alejo
    Alejo Member
    Alejo
    Fl
    98 prerunner, 2.7, acces cab
    Fuel line bent?
  11. Mar 22, 2011 at 11:12 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    If you use a flammable gas like propane or oxygen from a torch and spray it around seal areas or hoses you can detect vacuum leaks. The idle RPM will increase if a leak is present.
  12. Mar 22, 2011 at 11:16 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    RPM can be 1,500 to 6,000. makes no difference... only thing that matters is throttle position. To the floor and it never misses...
    As for the bent fuel line... no, I checked it when I was having other issues. No bends.
  13. Mar 22, 2011 at 11:18 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    In the FSM it mentioned a fuel cutoff at 3500 RPM with a restart at 1400 RPM.
    Maybe the throttle body is sticking? Needs a good cleaning?
  14. Mar 22, 2011 at 11:21 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    ahh k gotcha, just never heard that called a spray test
  15. Mar 22, 2011 at 11:25 AM
    Tacomatt23
    Tacomatt23 Member
    when you changed out all those parts in the fuel system did you change the fuel filter? that would be the first thing I would have changed.
  16. Mar 22, 2011 at 11:38 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Mass Air Flow Sensor?????
  17. Mar 22, 2011 at 6:12 PM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    yes, changed. Possible its a bad filter? Wouldn't a filter cause more of a spitting and sputtering hesitation miss rather than just it cutting off totally???
    That should throw a Check engine code. Too much $$$ in it now for another guess.
    I know how to test that, but I have no idea what the actual test is.
  18. Mar 23, 2011 at 7:37 AM
    90YotaPU
    Union County, NJ
    Easiest thing to do is go buy MAF Cleaner at Autozone or Pepboys and spray the internal part. Mine went twice on my '99. First time I replaced it, second time I cleaned it.
  19. Mar 23, 2011 at 7:53 AM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    Casper the friendly Taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver
    Throttle position sensor? If it had a distrubutor id say ignition module but that's ruled out.
  20. Mar 25, 2011 at 7:08 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Took the advise of a few and tried the TPS. It was a $58 gamble that I was unsure of since the check engine light was not coming on, and no codes in the computer. I have an appointment at the local Toyota dealer for Wednesday to get it checked out ($80 hr).
    I changed the TPS last night... Drove the truck about 60 miles or so since... Not a single stutter.... I am going to have to guess it was the TPS and it is now fixed.... Thanks everyone.
