needing rear shocks....
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kuneff, Sep 28, 2010.
  1. Sep 28, 2010 at 7:14 PM
    Kuneff
    Kuneff [OP] Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Ok, my new NAPA OEM replacement shocks are all the way extended... Any suggestions on a good +3" to +4" rear shock??? I have the 5100's up front...
    Any idea what OEM shock would fit that is just longer than a tacoma???
    95 4x4
  2. Sep 28, 2010 at 11:40 PM
    1998tacoma4x4
    1998tacoma4x4 Well-Known Member
    Orange County
    1998 Tacoma 4x4 3.4L Auto
    Deaver j59 pack 2.5 SAW coilovers, rear bilstein 5100's. Extened stainless rear brake line, deck plate mod, drop in K&N filter, Kenwood headunit & pioneer speakers, SnugTop Shell.
  3. Sep 28, 2010 at 11:54 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    I'm running 5100's all the way around. I only have a 1" lift on the rear though. I think the 5125's or 5150's are longer.
  4. Sep 29, 2010 at 12:01 AM
    1998tacoma4x4
    Orange County
    The 5100's accommodate 0 to 3" of lift.
  5. Sep 29, 2010 at 5:39 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I like my OME N85s.
  6. Sep 29, 2010 at 10:25 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    OK, I am looking at the 5150's.
    My truck at ride height has my current shock at 19" center to center.
    What kinda shock travel do I need in all reality? I have a 1.5" shackle coming for the truck, and I am still in debate about that. I have the AAL already on the truck and its sitting just about level, so I will probably be putting the Shackle on so that I can haul stuff without the back being all squatted.
    This truck WILL be seeing some off road fun, along with being used to clear off 2 acres of wooded property.
  7. Sep 29, 2010 at 11:04 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Basically I am looking at 2 different ones...
    14.17" Compressed / 22.5" Extended. 8.5" travel
    and the
    15.89" Compressed / 25.91" Extended. 10" travel
    Not sure which way would be better. Right now WITHOUT the Shackles I had to have my buddy sit on the tailgate to get the shocks back on. so the shorter ones will vie me 3" more downward travel...
    SO, I am looking at the idea that I will either be limited with 2-3" of downward travel with the shorter ones... or limited to 3" of Upward travel with the bigger ones...
    Anyone have any thoughts????
  8. Sep 29, 2010 at 9:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    You could measure each side when fully compressed and fully extended. Most accurate would be with the shocks removed. What is the maximum and minimum? The numbers will be different on each side.
    With those 4 measurements you'll know exactly which 5125 will fit the best and never over compress or extend.
