Needing some info on wheel spacers
Discussion in 'Wheels & Tires' started by chaos316, Oct 21, 2011.
  1. Oct 21, 2011 at 12:41 AM
    chaos316
    chaos316 [OP] Well-Known Member
    JJ
    Wichita, KS
    2011 Super White DCLB Sport 4x4 3" Spacer lif
    3" Revtek Spacer lift and aal, 18" Gear Alloy wheels, Nitto terra grapplers
    Can you use wheel spacers on the front only?
    what are the best ones?
    how much space do i need?
    I have a 2011 dclb sport 4x4 with a 3inch lift and 18s that are rubbing at almost full turn
  2. Oct 21, 2011 at 7:25 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    What size tires? What's the backspacing of your wheels?
  3. Oct 21, 2011 at 7:26 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    if your rubbing at full turn, spacers will make it way worse. just trim the plastic
  4. Oct 24, 2011 at 5:43 PM
    chaos316
    JJ
    Wichita, KS
    i have nitto terra grappler all terrains lt285/65r18
  5. Oct 25, 2011 at 5:48 AM
    KPT
    09 Prerunner
    I'm asking because depending on the backspacing of the wheels, spacers could make the rubbing worse.
  6. Oct 25, 2011 at 5:59 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Yes
    Spidertrax
    They come in 1.25"
    Also, what KPT said.
  7. Oct 25, 2011 at 5:11 PM
    chaos316
    JJ
    Wichita, KS
    i have no idea how to find out what my backspacing is. i bought the truck with a 3 inch spacer lift from revtek with the wheels and tires. is it on that back?
  8. Oct 26, 2011 at 4:16 AM
    KPT
    09 Prerunner
    You can either take the wheel off and measure the backspacing (consult link below), or if you can find any stamping on them rim, such as "18x9JJ ET-12" or something like that, post it here and we can decode it for you.
    https://www.rsracing.com/tech-wheel.html
  9. Oct 26, 2011 at 8:00 PM
    chaos316
    JJ
    Wichita, KS
    alright thanks a bunch guys. when i have time ill take a look.
  10. Oct 26, 2011 at 8:13 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    false.
    they bolt to the hub, and then the wheel is bolted to them.
    It's the exact same as having a wheel with more backspacing, which is fine.
    wheel shims can be more of an issue.
  11. Oct 28, 2011 at 8:38 AM
    gassman
    gassman Well-Known Member
    oklahoma
    06 TRD 4x4
    3'' lift, TRD exhaust, Bilstiens, PIAAx4 with N-Fab light bar
    IMHO avoid them!!!, almost had catastrophic crash when one broke off rear wheel
