Needle bearing catastrophic failure?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JLaScala, Jul 1, 2016.
  1. Jul 1, 2016 at 11:43 PM
    JLaScala
    JLaScala [OP] Super White is gonna treat you right.
    Snohomish Washington
    2010 TRD Sport 4x4 long bed crew cab.
    Secondary air filter removal, K&N drop in, Removed front mud flaps, Toyota all weather matts, skid plate, bug guard. Bilstein 5100's all around fronts set at 2.5", OME add a leaf, Goodyear Wrangler Authority 265/70/17, stubby 6.5" antenna, smoked tail lights, blacked out badges.
    Simple question. Has anyone heard of there being a catastrophic failure of the front differential needle bearing in the Second gen Toyota Tacoma. I looked through the vibe thread and couldn't find anything. I'll admit though I wasn't up to looking at all 185 pages...... I'm going to be doing the ECGS bushing fix next weekend and was just curious about how serious of a problem it is. I have yet to hear anything about a damaged diff or even a cv. The vibes and sound are annoying as all hell though.
  2. Jul 2, 2016 at 12:04 AM
    75z28
    75z28 Well-Known Member
    Homer
    2017 OR 4x4 DCLB SSM
    Yes, not necessarily a Tacoma, but solid roller lifters love to come apart(they use needle bearings) and destroy big block and small block chevys
    US Marine likes this.
  3. Jul 2, 2016 at 12:32 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I think he's specifically refering to the needle bearing used in the Tacoma front diff arrangement
  4. Jul 2, 2016 at 12:45 AM
    JLaScala
    I wasn't being specific enough thanks OZ-T. Post edited.
  5. Jul 2, 2016 at 4:06 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    I am sure its happened, but remember they really only have load on them when your in 4wd. What 75 z28 says is true I have a 1998 corvette and the roller rocker arms failing is common...happy 4th
  6. Jul 2, 2016 at 9:15 AM
    JLaScala
    I appreciate your comment, but unfortunately that is a completely different vehicle and manufacturer. For as many people who have changed out the differential needle bearing, I'm surprised that nobody has a horror story yet. Specific to the second gen Tacoma of course. Post edited again to be even more specific.
  7. Jul 2, 2016 at 10:34 AM
    scottfarm
    scottfarm Well-Known Member
    Florida
    tacoma 4X4
    aires 3D mats, scan gauge II, rear differential breather relocation, and bakflip G2 bed cover.
    Is it lifted
  8. Jul 2, 2016 at 10:36 AM
    Pigpen
    Dan
    Northwest Montana
    My bearing had the hum for about 12K miles after my lift. When I had the bushing put in, my mech showed me the needle bearing and it looked brand new.
    JLaScala[OP] likes this.
  9. Jul 2, 2016 at 10:52 AM
    tacoma4
    tacoma4 Well-Known Member
  10. Jul 2, 2016 at 3:38 PM
    JLaScala
    Lifted and non lifted trucks develop this problem.
  11. Jul 2, 2016 at 3:40 PM
    JLaScala
  12. Jul 3, 2016 at 10:31 AM
    JLaScala
    Still nothing? I'm beginning to think this is just an annoyance rather than a necessary fix.
  13. Jul 3, 2016 at 10:46 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    While not 'catastophic', what you state in your OP would qualify replacing the needle bearing as necessary in my book.
  14. Jul 3, 2016 at 11:09 AM
    JLaScala
    That's why I'm doin it.:cool:
