Needle Bearing ECGS and TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JaseVernon, Aug 28, 2015.
  1. Aug 28, 2015 at 10:04 AM
    JaseVernon
    JaseVernon [OP] Active Member
    Vernon BC Canada
    SR5
    So I searched but there is a ton of information to go through. I just purchased my ECGS Bushing and was going to install it soon, but I just spoke with my dealer and they said a TSB was just released for the needle bearing for the exact reason the bushing was developed.
    Has anyone done the TSB? and if so, do they deal with the bushing problem too? Is it worth just doing the TSB vs the Bushing?
    Any thoughts would be great!
  2. Aug 28, 2015 at 10:18 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    i have not heard about any TSB.... but honestly just use the ECGS bushing.... not worth your time n energy to deal with the dealer.
  3. Aug 28, 2015 at 10:21 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I disagree. Use your dealer for the tsb. If it's still a problem later then you could always do the new bushing.
    Hartford likes this.
  4. Aug 28, 2015 at 10:29 AM
    JaseVernon
    Vernon BC Canada
    SR5
    I agree with you...its not much more with parts and labor to have them do the TSB, so I just thought if they have done something to fix it, I get the needle bearing replaced, the issue fixed, I don't have to give up my time and all for only $250 more than I have into the ECGS parts and puller. If it truly fixed the issue, I will probably go that way, I just want to know it actually fixes the issue.
    I am going back to the dealer today so I will get more details on the TSB.
  5. Aug 28, 2015 at 11:10 AM
    nd4spdbh
    SoCal
    get us a TSB number and see if you can get a printout of the TSB.'
    if they are just replacing the needle bearing with a new one... its pointless as the problem will persist. If they are replacing it with an actual ECGS bushing or something like an ECGS bushing, then have them do it.
    BassMaster06 likes this.
  6. Aug 28, 2015 at 11:17 AM
    Pigpen
    Dan
    Northwest Montana
    I would not want to replace a shitty part with another shitty part. Maybe see if they'll install the bushing you already have under the TSB.
    EB Group likes this.
  7. Aug 28, 2015 at 11:20 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
  8. Aug 28, 2015 at 12:20 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    What year is your truck? TSB is free under warranty. If it's not free then use the ECGS bushing.
  9. Aug 28, 2015 at 12:26 PM
    nd4spdbh
    SoCal
    honestly i wouldnt even trust them to do that.... the ECGS bushing is longer and they would probably drive it all the way in like it was the bearing and bind everything up.
  10. Aug 28, 2015 at 12:36 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I thought I read that Toyota was testing the ECGS bushing for possible implementation
  11. Aug 28, 2015 at 6:04 PM
    Pigpen
    Dan
    Northwest Montana
    Good point
  12. Aug 28, 2015 at 6:07 PM
    Ellman605
    Ellman605 Well-Known Member
    Elliott
    Glen Dirty, MD
  13. Aug 29, 2015 at 1:23 PM
    andyzx6r
    andyzx6r Well-Known Member
    Atlanta
    Super White TRD Sport
  14. Aug 29, 2015 at 1:44 PM
    DougsGraphics
    DougsGraphics Duck Hunter!
    Doug
    Northern New Mexico
    2015 Pyrite Mica DCSB TRD OR
    3" Revtech Level, ARB Deluxe Bull Bar front bumper with WARN 9.5XP Winch and KC Pro-Sport LED Driving Lights, black Diamond Back HD tonneau cover, 4 cameras through Entunes display with capacity for two more, LED interior lights with map lights tied to dome, Bussman auxiliary fuse/relay box with 100 amp breaker/disconnect under hood.
    Sounds like the instruction is a straight up replacement? I had mine in and, because it is intermittent, they couldn't find a problem. Now that I have a camera under there, I can observe the front propeller shaft spinning up as a result of the binding of the CV axle spinning up the differential. I'm going to video that for the next time I can get to the dealer.
  15. Aug 29, 2015 at 2:27 PM
    YotaDriver631
    '18 Taco
    Wow this is great news! Gonna show my dealer this issue and see how it goes.. I wonder if the bearing they install is of smaller insider diameter or direct replacement.
  16. Aug 29, 2015 at 2:34 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
  17. Aug 29, 2015 at 2:37 PM
    Ellman605
    Elliott
    Glen Dirty, MD
    Called two dealers neither of them knew about it. Glad we have a scan. Gonna take this to them and ask
  18. Aug 29, 2015 at 2:52 PM
    Ellman605
    Elliott
    Glen Dirty, MD
    Any chance you can throw up a full picture of both pages?
  19. Aug 29, 2015 at 5:32 PM
    andyzx6r
    Atlanta
  20. Aug 29, 2015 at 6:06 PM
    nd4spdbh
    SoCal
    10 bucks says its simply replacing the needle bearing with the same thing, inspecting and replacing the CV if any signs of wear.
    Id be real impressed if they actually took a page out of ECGS's playbook and used a longer PTFE bushing rather than a needle bearing.
    The rest of that TSB will lend to the tale of whether or not a different part number is used in place of the Offending Part
