Needle Bearing ECGS and TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JaseVernon, Aug 28, 2015.
  1. Sep 6, 2020 at 6:07 PM
    #301
    FarmBoyTaco
    FarmBoyTaco Work Hard, Stay Humble
    Josh
    California
    '12 TRD Off-Road DCSB MGM
    If Toyota puts out a TSB it means it’s a problem with stock trucks. It just becomes more noticeable with lifted trucks
    Captainskidmark likes this.
  2. Oct 22, 2020 at 12:12 PM
    #302
    elavado
    elavado Member
    Did they end up correcting the problem! I have a 2020 and have a weird rotation vibe at low speeds after lifting.
  3. Oct 22, 2020 at 12:12 PM
    #303
    elavado
    elavado Member
    Even more strange, it was not there for first week after lift, then appeared.
  4. Oct 22, 2020 at 2:11 PM
    #304
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    Not really strange. That’s just how the needle bearing problem goes. I didn’t have it for a long while... then I did. Then I put the bushing in and never thought about it again.
    edit: put it in 4hi. Does the weird droning sound go away?
    if you answered yes- needle bearing.
    dk_crew likes this.
  5. Oct 22, 2020 at 4:05 PM
    #305
    snook 32
    snook 32 Well-Known Member
    Herb
    Davie Florida
    08 pre runner
    I thought it was for the 2nd. Gen. only with the bearing taking a crap, give ECGS a call they should be able to help you figure this out
  6. Oct 22, 2020 at 6:49 PM
    #306
    elavado
    elavado Member
    ok that is what I was thinking also, I will give them a call. thanks
  7. Oct 25, 2020 at 3:25 PM
    #307
    Fastrat
    Fastrat Well-Known Member
    Fort Walton Beach, FL
    2014 DCSB Baja
    Just swapped mine out, might be the best $60 I've spent on the truck. I had the cyclical vibe between 35 and 40 mph that went away when switching into 4wd, 2014 Baja with 67k miles. Wasn't too difficult, although I'd recommend an actual puller instead of the slide hammer type as it wouldn't move for me. Everything else is easily found on this forum.
    dk_crew and Kyle01 like this.
  8. Nov 2, 2020 at 6:20 AM
    #308
    elavado
    elavado Member
    if anyone has one of those pullers let me know! seems a bit expensive to buy it new for what it is.
  9. Nov 2, 2020 at 2:18 PM
    #309
    Fastrat
    2014 DCSB Baja
    There’s a thread in the marketplace for people passing theirs along. I’d check there.
