Needle Bearing ECGS and TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JaseVernon, Aug 28, 2015.
  1. Aug 29, 2015 at 6:10 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Damn I just bought the whole kit and kaboodle for this from ECGS. Over 200.00 clams. I would highly doubt Toyota would not put in the same crappy bearing that is already in there. Just like if they replace your wheel bearings that go all the time. I believe they put he same garbage right back in.
  2. Aug 30, 2015 at 5:28 AM
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
  3. Aug 30, 2015 at 7:01 AM
    glock24
    glock24 Well-Known Member
    I still say let 'em do it, even if you go back the next day and install the bushing. At least this way, you can let Toyota deal with rusted bolts, or replacing CV damage.
    NC15TRD and Ellman605 like this.
  4. Aug 30, 2015 at 7:40 AM
    Ellman605
    Ellman605 Well-Known Member
    Elliott
    Glen Dirty, MD
    This all the way. Plus, the cv will be freshly removed, so probably easier to remove for the ecgs bushing
  5. Aug 30, 2015 at 7:42 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I wonder if they will use my bearing I already have??
  6. Aug 30, 2015 at 8:14 AM
    Ellman605
    Elliott
    Glen Dirty, MD
    Doubt that. But who knows. Try it out and see. If it works, I'll order mine and try that at the dealer
  7. Aug 30, 2015 at 8:17 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I ordered it just to have it. How will I know if I actually need it yet? I am only leveled out front at 1.75. But have heard any lifting means I will need it.
  8. Aug 30, 2015 at 9:01 AM
    Ellman605
    Elliott
    Glen Dirty, MD
    If you install the lift yourself, I'd do it anyway just to do it. You'll already be halfway disassembled. I wish I had known about it while I was doing my lift.
  9. Aug 30, 2015 at 9:01 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Mine has been lifted since October. Too late for me to do it.
  10. Aug 30, 2015 at 9:42 AM
    Ellman605
    Elliott
    Glen Dirty, MD
    You're probably fine then. Mine was lifted around June and I just started experiencing issues. But I'm also around 2.5"
  11. Aug 30, 2015 at 10:13 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    did 1.75in of lift on the front of my truck... instantly noticed the vibe. Spent 60 bucks on the ECGS bushing and made my own bearing puller. took an hour and did it myself. Zero issues since.
  12. Aug 30, 2015 at 10:26 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Nice to be handy like that, I for one am not. Anybody want to come do mine? I have the whole kit, and when your done you can have the kit for free
  13. Aug 30, 2015 at 10:39 AM
    Pigpen
    Dan
    Northwest Montana
    I paid to have mine done. My vibe showed up as soon as I lifted. If you don't have the vibe, I wouldn't be in a hurry. Check out the 4x4 diff bearing vibe MEGA thread if you are unsure about the symptoms. I had my vibe for about 10 k miles and my mechanic said there was no wear on the axle - he even showed me the bearing and it looked fine too.
    Shit. I thought it was a sticky. Looking for it...
  14. Aug 30, 2015 at 10:53 AM
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    So since this is a TSB, Toyota will replace the part even after warranty expires? I am lifting in the next month or two around Black Friday, and shortly after that my warranty will expire.
  15. Aug 30, 2015 at 10:58 AM
    #35
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No , thats a recall
  16. Aug 30, 2015 at 10:59 AM
    #36
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Just to clear things up for myself here...is this going bad before or after lifts? Or is it just a chance thing that is going bad either way? Planning on lifting in a few months and if it's going bad cause of lifts then I will just do it then.
  17. Aug 30, 2015 at 11:00 AM
    #37
    Pigpen
    Dan
    Northwest Montana
    Most experience the problem after lifting
  18. Aug 30, 2015 at 11:06 AM
    #38
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    So then they will replace it while I am stock before I lift, since I am under warranty? Or are they going to say the classic "cannot duplicate"? I was under the impression TSB's had to be done regardless.
  19. Aug 30, 2015 at 11:13 AM
    #39
    Ellman605
    Elliott
    Glen Dirty, MD
    Tsb is under drive train warranty. 60k.
  20. Aug 30, 2015 at 11:19 AM
    #40
    nd4spdbh
    SoCal
    really need the rest of the TSB to see what they are actually doing.
    Ellman605 likes this.
