Needle Bearing ECGS and TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JaseVernon, Aug 28, 2015.
  1. Aug 31, 2015 at 2:17 PM
    #61
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Anyone have a link to a DIY thread for changing these out? I searched and oddly didn't get any results back... mostly just people selling their used removal tool.
  2. Aug 31, 2015 at 2:18 PM
    #62
    Old School
    Old School You are ignoring covfefe by this member.
    Thanks to OP for posting this thread, I went by the dealer today, had my service advisor look up the TSB, and order the parts listed.
    I think it's worth letting my dealer take a shot at fixing this issue, if it doesn't work, it should give me some leverage to getting them to do the ECGS bushing.
    If nothing else, I have a paper trail with Toyota for warranty documentation...
    ready6delta likes this.
  3. Aug 31, 2015 at 2:58 PM
    #63
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    https://www.youtube.com/watch?v=WnA_R3gFf2s
  4. Aug 31, 2015 at 2:59 PM
    #64
    lawrenccar1
    you have the vib issue ?
  5. Aug 31, 2015 at 3:00 PM
    #65
    Old School
  6. Aug 31, 2015 at 3:01 PM
    #66
    lawrenccar1
    on what kind of lift ? I must be lucky thus far..
  7. Aug 31, 2015 at 3:04 PM
    #67
    Old School
    It was doing it before the 3" spacer lift, yeah I know, gonna put better shocks and springs later...
  8. Aug 31, 2015 at 3:04 PM
    #68
    andyzx6r
    andyzx6r Well-Known Member
    Atlanta
    Super White TRD Sport
  9. Aug 31, 2015 at 3:06 PM
    #69
    lawrenccar1
    wow a stock 2015 (assume that is what u have) was doing it before lift.. yuck..
  10. Aug 31, 2015 at 3:38 PM
    #70
    Ellman605
    Ellman605 Well-Known Member
    Elliott
    Glen Dirty, MD
  11. Aug 31, 2015 at 3:58 PM
    #71
    JaseVernon
    JaseVernon [OP] Active Member
    Vernon BC Canada
    SR5
  12. Aug 31, 2015 at 4:01 PM
    #72
    JaseVernon
    Vernon BC Canada
    SR5
    As far as my truck, its not under warranty (2005), if it was I would do it and if nothing else then do the ECGS after. I am interested to hear if anyone gets this done if it is successful before I pony up the $.
  13. Aug 31, 2015 at 4:13 PM
    #73
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    lol looks like they are using the same damn part..... and even if it is a different needle bearing, its still a needle bearing thats too short to support the CV properly.
    dont even bother with this TSB it aint gonna fix any thing
  14. Aug 31, 2015 at 4:15 PM
    #74
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    How do you know this? I have not looked at the documents though
  15. Aug 31, 2015 at 4:18 PM
    #75
    nd4spdbh
    SoCal
    Pictures from the document as well as if you look up the part number in an OEM fiche the title of the part is "BEARING, NEEDLE ROLL"
  16. Aug 31, 2015 at 4:20 PM
    #76
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    See typical Toyota replacing garbage with garbage.
  17. Aug 31, 2015 at 4:20 PM
    #77
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Shit!!!!
  18. Aug 31, 2015 at 4:24 PM
    #78
    nd4spdbh
    SoCal
    Now i can not confirm that this is the same part number as the original needle bearing .... and more than likely it is the same part but they are still putting a needle bearing back in.
    So either come to an agreement with the toyota dealer to have them do the labor and you supply the ECGS bushing, making a BIG NOTE that it is NOT to be driven in all the way as it is longer.... or simply dont even bother with the tsb in the first place and get the ecgs bushing installed at a local mechanic you trust.
  19. Aug 31, 2015 at 5:21 PM
    #79
    Pigpen
    Dan
    Northwest Montana
    I paid around $250 IIRC. It was the first one my mechanic had ever done, so I'm sure someone with a little more experience could do it faster (may or may not charge less).
  20. Aug 31, 2015 at 5:45 PM
    #80
    nd4spdbh
    SoCal
    The biggest thing is having the proper tool to pull it out as there is not much room. I made my own, but it took me a good hour of slowly shaping the pulling piece to fit properly in the diff to pull the old one out.
    Crom likes this.
