Needle Bearing Failure With Lift (How Many)
Discussion in '3rd Gen. Tacomas (2016+)' started by Harvo, Apr 17, 2017.
Have you experienced front end vides or needle bearing failure after lifting your truck?
  1. Yes
    155 vote(s)
    43.2%
  2. No
    144 vote(s)
    40.1%
  3. I installed the bushing when I installed the lift
    60 vote(s)
    16.7%
  1. Apr 17, 2017 at 1:39 PM
    Harvo
    Harvo [OP] Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    This forum has a decent percentage of 3rd gen owners who lift their trucks (whether to take off road or not). It is a well documented fact on TW that the driver side needle bearing fails on some trucks when lifted. (And in a smaller amount without a lift). It would be interesting to hear from as many people as possible, who have lifted their 3rd gens, and find out if they have experienced (or are experiencing) noise or vibes from the front end that are likely caused by the needle bearing issue. Also to hear from those who have lifted and experienced NO issues as stated above.
    It could show a very rough estimated percentage of trucks that get away with a lift without experiencing the issues and the ones that have the failures due to lift. This could be used to either convince MORE people that the bushing fix is practically mandatory, or give others a more calculated risk factor of not doing the mod. As someone who is about choose a lift / lift height / and needle bearing delete ... I know this info would be telling.
    It would be great to keep the info you post to only include
    Year 16 or 17
    Amount lifted
    Vibes / Noise (bearing issue) or not
    If you did the Bushing mod before you had an issue... mention that as well
    Hopefully this will gather useful info.
  2. Apr 17, 2017 at 1:40 PM
    Harvo
    And like a dork I misspelled Vibes in the Poll :facepalm:
  3. Apr 17, 2017 at 1:43 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    2016, lifted 1.5", developed the vibrations immediately after lifting.
    I replaced the needle bearing the very next week. Smooth like butter now.
    Paris0514, Wakecoach and stevotivo12 like this.
  4. Apr 17, 2017 at 3:20 PM
    NIU_Huskies
    NIU_Huskies Well-Known Member
    2017 Toyota Tacoma TRD Sport DCLB
    Good idea for polling this. I'm going to lift my truck in the next few months but I was contemplating waiting for the needle bearing issue to show up before I went and spent all the time and money on something that may not even actually occur after lifting.
  5. Apr 17, 2017 at 3:27 PM
    smitty99
    Scottsdale
    The gamble is effectively $200-$300 worth in extra labor or 3 to 4 hours of time if you can DIY. Only reason is because they'll have to pull apart the driver's side front suspension again to get in there and replace it.
    Wakecoach likes this.
  6. Apr 17, 2017 at 3:31 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    If your lifting the truck i would just do it and say good riddance. The truck will be apart for the lift anyhow and whats a few extra hundred bucks for peace o mind.
    remgu2000, Wakecoach and smitty99 like this.
  7. Apr 17, 2017 at 3:44 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    OP, you could also add one option for those that have not lifted and have had the bearing fail. Like myself.
    smitty99 likes this.
  8. Apr 17, 2017 at 3:49 PM
    smitty99
    Scottsdale
    I think the big determining factor for me would be if he's installing the lift himself or not.
    If you can install the lift yourself you're saving a ton of money in labor right there. So paying out of pocket to have someone go back and replace the ECGS bushing isn't going to hit your wallet as hard.
    If you have to pay somebody to install the lift ($400-$500 in labor) then go back and pay the same sumbitch to pull the drivers side back apart and put together again you're going to be out another $200 to $300.
  9. Apr 17, 2017 at 5:07 PM
    Harvo
    I just think it's good information to present so people can take calculated risks. Speaking for myself... I am a capable shade tree mechanic. I can do a suspension with no issue. When I get into using a strange tools on unfamiliar vehicles (bearing puller) that I could potentially drop a piece into the diff with, I might more consider taking it to a shop that knows Toyota front ends. If the poll shows only a small percentage have issues, I might be more inclined to do the lift first and the bearing only if trouble arises (and pay someone to do that part).
  10. Apr 17, 2017 at 5:35 PM
    Flytmech
    Flytmech Well-Known Member
    Jase
    Geneva Alabama
    2016 Tacoma TRD OFFROAD 4x4
    All Pro Offroad bed rack Defender Basket OME/Dakars Total Chaos ucas C4fabrications LoPro Smittybilt 9.5 comp Uniden 520xl (tuned) CVT Mt. Shasta Black Oak 50 curve led
    Mine vibes at 40/45. After OME lift. Gotta do the bushing.
  11. Apr 18, 2017 at 4:30 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    2016 Sport, did front 5100, set at notch 4 (1.5"). get vibes now. thinking about moving them back to 3rd notch (1.1") to see if that helps for now..
  12. Apr 18, 2017 at 6:08 AM
    smitty99
    Scottsdale
    Needle bearing is shot. Replace it.
    bajatacoguy likes this.
  13. Apr 18, 2017 at 6:19 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Bilstein 5100's TRD Beadlocks Timbren Bump Stops SPC UCA SuperSprings SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    Just do the ECGS Bearing & be done!
    ScottyR and smitty99 like this.
  14. Apr 18, 2017 at 9:25 AM
    rlx02
    rlx02 Well-Known Member
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    stuff
    2.25" right now. No vibes so far.
  15. Apr 18, 2017 at 10:05 AM
    blkbelt42
    blkbelt42 Well-Known Member
    2016 AT DCSB 4x4 TRD Sport
    JL Audio C2690tx Speakers Alpine MRV-F300 JL Audio 10" Sub - Full length Ported Box Kicker Tweeters BFG KO2's 265/70/17 Tint N-Fab Bars Husky WB Mats AVS Visors Console Divider Tacoma Tonneau Cover ALL PRO 1.5" wheel spacers aFe CAI w/ Dry filter TRD Wheels Custom Remote Start TRD Pro Grille ECT always-on mod by MESO OV-Tuned - 1.03 ROAV Dash Cam 3" RC Lift
    is it the height of the lift causing needle bearing failure
    or will any amount of lift trigger it?
  16. Apr 18, 2017 at 10:14 AM
    elduder
    elduder Well-Known Member
    Van WA
    2018 6MT TRDOR DCSB Cement
    I test drove stock trucks with the issue.
    My truck is a 2017, lifted with 887s and had vibes the same day I lifted it. Would come and go at first but eventually became a constant at 40 mph. Replaced it with ECGS bushing and its been quiet since.
    blkbelt42 likes this.
  17. Apr 18, 2017 at 10:14 AM
    smitty99
    Scottsdale
    There's a design flaw with the way Toyota designed the CV shaft to sit installed inside the carrier, there's about 50 thousandths of an inch of play. Toyota didn't machine the carriers, it's just cast inside there...so there's more slop for the spider gear to sit in. So the spider gear is supporting the CV shaft (as installed by design) as much as the needle bearing is. If you add a lift to it, it exaggerates the angle and the amount of runout, causing more movement and vibrations due to the slop and pressure on the needle bearing.
    The ECGS bushing tightens up that clearance.
    It can fail on non-lifted trucks as well. Just ask @swimmer
    remgu2000, oldtoyotaguy and Jaggerbub like this.
  18. Apr 18, 2017 at 10:19 AM
    blownoutsundays
    blownoutsundays Member
    Doug
    I got the vibration after installing 5100/OME 886 (2.5") on my 2016. I've had the vibration for about 1500 miles. HOWever - now that it's getting warmer out, the vibration has gone away. I know it still needs to be replaced sometime this summer before it gets cold out again, but for now, I am vibration free.
    I wonder if the heat somehow affects the fit of the needle rollers in the bearing, creating a tighter fit. We're talking about 40 degrees though so that's a little hard to believe. Anyone have any thoughts on this phenomena?
  19. Apr 18, 2017 at 10:23 AM
    smitty99
    Scottsdale
    Heat causes metal to expand. A little more heat can cause tighter clearances leading to less slop. See my explanation of why it vibrates above for the correlation.
  20. Apr 18, 2017 at 10:25 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Bilstein 5100 shocks w/ 1" rear block - American Racing AR969 Ansen wheels - LT265/75/16 Toyo Open Country A/T II load C - TacomaBeast halo projector lights - Bullet Proof Fab skid plate w/ Line-X - NFab 3" step bars - OEM roof rack - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - LED interior lights - Sylvania Silver Star Ultra headlight bulbs - Sylvania Zevo 921 LED license plate/reverse ligths - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - Center console organizer - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Coverking Neosupreme seat covers - Receiver hitch w/ D-Ring - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights - Stickers n shit
    Second gen guy checking in. Had a 2.5" 5100 lift installed and the vibes began. I got the dealership to do the TSB on it at no charge. Figured I lucked out because they never mentioned the lift at all, just did it without question. So far, so good 1000 miles later.
    NIU_Huskies and Humboldt_Homie like this.
