Needle bearing issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacowarrior69, Nov 1, 2016.
  1. Nov 1, 2016 at 4:12 PM
    Tacowarrior69
    Tacowarrior69 [OP] Member
    Kevin
    08' Tacoma Access TRD Off-road
    Hello everyone, brand new to the forum. Here's my first post.. I have owned my 08' Taco for almost a year now and love it. Only have a few things about the truck...
    It seems to have the "needle bearing hum" in the front and was wondering if anybody had the removal tool they dont need anymore? I plan on fixing this fairly soon. Let me know what you have.
    Only other thing I can complain about is the slip yoke bind. Haven't dropped the drive shaft yet to check it out but it's on my to-do list.
    Any help is appreciated!
  2. Nov 1, 2016 at 4:30 PM
    Normantaco
    Normantaco Well-Known Member
    Pensacola, Fl
    16 4Runner SR5
    Hi, and welcome. I replaced mine with the ECGS bushing and did not use their removal tool. I used a rental tool from I believe O'reilleys. Pilot bearing puller I'm pretty sure it was called. Threaded onto a slide hammer. Used that, bearing driver kit, slide hammer. For CV removal I used a large pry bar. There is a ECGS bushing thread on here that is very helpful.
  3. Nov 1, 2016 at 4:52 PM
    Tacowarrior69
    Kevin
    Did the bushing completely cure the symptoms your truck was having? (vibrations, hum, etc..)
  4. Nov 1, 2016 at 5:13 PM
    Pigpen
    Dan
    Northwest Montana
    The bushing completely solves any issue resulting from the shitty OEM bearing.
  5. Nov 1, 2016 at 5:22 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Is this a repair you can do at home or do things have to be pressed at a shop?
  6. Nov 1, 2016 at 5:33 PM
    Normantaco
    Pensacola, Fl
    16 4Runner SR5
    Yes it completely solved the vibe/hum.
    You can do this at home, no shop pressing necessary. There is a thread devoted to this issue, plus ECGS provides an installation guide.
    Crosis[QUOTED] likes this.
  7. Nov 1, 2016 at 5:34 PM
    Normantaco
    Pensacola, Fl
    16 4Runner SR5
    I'm about 10k miles out from the repair, and no vibe or hum since, and I have cranked my coilovers up a little bit more since the bushing install.
  8. Nov 1, 2016 at 6:09 PM
    Tacowarrior69
    Kevin
    Can't wait to get it done, my half hour commute drives me crazy with that f***ing hum. I just crank the tunes to drown it out :rockband:
    teamfast and Normantaco like this.
  9. Nov 2, 2016 at 5:53 PM
    Tacowarrior69
    Kevin
    I was hoping someone had this bearing puller I could buy off them instead of going through ECGS..
  10. Nov 2, 2016 at 5:56 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    @Up2NoGood here is a person you can send my free set of tools to brother
  11. Nov 2, 2016 at 6:01 PM
    Normantaco
    Pensacola, Fl
    16 4Runner SR5
