Needle Bearing Problem Info?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Flash1034, Oct 28, 2018.
  1. Oct 28, 2018 at 10:04 PM
    Flash1034
    Flash1034 [OP] Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    im new to Tacoma’s. I keep reading about this needle bearing. What is it, where is it, do I have one on my 2018, is there a preemptive move I should make to eliminate the problem? Does anybody have a picture of this thing and it’s location?
    Thanks
  2. Oct 28, 2018 at 10:06 PM
    tcjacado
    tcjacado Well-Known Member
  3. Oct 28, 2018 at 10:07 PM
    Bishop84
    Bishop84 Well-Known Member
    It's the support bearing for the front left CV axle shaft. Once the truck is lifted by aftermarket means it puts stress on a needle bearing that is designed for straight level wear. It is then upgraded and replaced by a solid bushing that allows for stress at an angle.
    Most 2016+'s with 2+ inch lifts end up with a vibration in 2WD that is felt by the feet. This is the only way to resolve it on a lifted truck.
    Taco16LB and tcjacado like this.
  4. Oct 29, 2018 at 9:40 AM
    Flash1034
    N/W Montana
    Awesome. Thanks for the great replies.
