Needle bearing removal tool
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JCM138, Apr 20, 2023.
  1. Apr 20, 2023 at 7:04 PM
    JCM138
    JCM138 [OP] Active Member
    2012 PYRITE MICA TRD OFF-ROAD DCSB
    Does anyone in the Prescott-Prescott Valley, AZ area have a needle bearing removal tool that I could borrow or rent? I’m a student at Yavapai College Automotive program and the bearing pullers we have in the shop did not work out for me. Wasn’t aware of the hassle it is to remove the needle bearing and now find myself here asking for help with a removal tool. Got everything removed except the bearing and now my truck is inoperable on a lift at school until I can finish this task. Any help or recommendations are greatly appreciated!
  2. Apr 20, 2023 at 7:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Apr 20, 2023 at 7:12 PM
    Bishop84
    Bishop84 Well-Known Member
    If you need the truck for the weekend, the only other alternative is to use a saw, either a hacksaw blade or a pneumatic saw and cut a slice into the needle bearing to collapse it, then pull it out.
    Far from ideal, but it's "getrdone" mode. Obviously fillings are a big concern but I've seen this method in a pinch.
    JCM138[OP] and HondaGM like this.
  4. Apr 20, 2023 at 7:15 PM
    JCM138
  5. Apr 20, 2023 at 7:16 PM
    JCM138
    one instructor suggested doing that hahaha.
  6. Apr 20, 2023 at 7:18 PM
    TnShooter
    Deogee
    STOCK
    Have you tried a blind hole bearing puller?
    JCM138[OP] likes this.
  7. Apr 20, 2023 at 7:36 PM
    JCM138
    I did try using one but the handle was too short and wasn’t allowing me to have good enough leverage to remove it out. Instead it started to drive the races out and eventually the race cage got mangled. Only the face/outside ring remains
  8. Apr 21, 2023 at 3:27 AM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    I ended up making a DIY version of the ECGS tool, with a hardened thick washer with 2 sides cut flat as the puller, a longish hardened bolt, and an old saw arbor I had laying around (but you could use a piece of whatever metal) to go against the housing. Wasn't pretty, but it did the job.
    I was hoping to get it with a blind hole puller from HF, but that wasn't doing diddly, so I needed something quick...
    toniodiaz, TnShooter and JCM138[OP] like this.
