Needle Bearing, Replacement with ECGS Bushing Shop Recommendation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Azza2, Jan 2, 2023.
  1. Jan 2, 2023 at 10:55 AM
    Azza2
    Azza2 [OP] Well-Known Member
    Yass
    AZ
    2021 TRD OR
    So my truck's humming is getting pretty bad and after reading the posts here I'm pretty sure the needle bearing needs to be replaced. The driver's side CV has some play also, not sure if that's normal or not. My question is if I should even bother with the dealer, truck is under warranty but even if they take responsibility might just replace the needle bearing which solves nothing. Wanted to check here if someone recommends a shop that can do the job here in AZ. I have no experience working with suspension and don't want to mess it up, I'm in the Phoenix area any suggestions are appreciated. Thanks.
  2. Jan 2, 2023 at 12:16 PM
    MattG88
    MattG88 Well-Known Member
    matthew
    AZ
    2021 Tacoma TRD
    Arizona toy pros, bulletproof off road, desert toy shop, westcott designs
    Azza2[OP] likes this.
  3. Jan 2, 2023 at 12:29 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Same as the gen2s and let the dealer look at it as hard to believe that bearing is bad on a 21. That drivers side CV on all Tacomas is a sloppy mess but I did not change to the ECGS bushing until 185,000 miles when it was CV axle time. The bushing did smooth it out alittle or maybe the new CVs. Humming could be many things based on how you use/abuse it and mileage.
  4. Jan 2, 2023 at 12:43 PM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Since you're not lifted, I highly doubt the bearing is bad. Probably the rear dif humming. Take it to the dealer
  5. Jan 2, 2023 at 12:46 PM
    Azza2
    Yass
    AZ
    2021 TRD OR
    I lifted it about 6 months ago with the Westcott lift. The humming started a week after the lift
  6. Jan 2, 2023 at 12:48 PM
    Azza2
    Yass
    AZ
    2021 TRD OR
    Hard to believe for me too but the symptoms are exactly the same as described here and on YouTube. I'll have the dealer take a look anyways see what they say, thanks.
  7. Jan 2, 2023 at 12:51 PM
    TacoSupremo19
    NJ
    Ok, you didn't mention you were lifted and you profile says Stock so ECGS bearing might be a possible solution.
  8. Jan 2, 2023 at 12:52 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    try the reginal subforums, you'll most likely get more local support there.
  9. Jan 2, 2023 at 12:53 PM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    Does switching on the 4WD make the hum go away?
    [If yes, it is likely the needle bearing, if no - next]
    My 2nd gen is lifted and it had a hum, only when it was cold out between 30-40 mph, @ 61K - I live near ECGS so I just had them R/R the part and do the CV boot/front diff fluid.
    Solved my hum issue.
  10. Jan 2, 2023 at 12:53 PM
    TacoSupremo19
    NJ
    Dealer will see the lift and say that's the problem. The poster here probably thought what I thought
  11. Jan 2, 2023 at 12:58 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Reachout https://www.tacomaworld.com/forums/arizona.84/
    Azza2[QUOTED][OP] likes this.
  12. Jan 2, 2023 at 1:01 PM
    amyracecar
    Virginia Applejack
    SouthEast USA
    If you have a good relationship with the dealer/service dept - maybe you can buy the ECGS needle bearing and just have them do/cover the labour under warranty - it is not an unreasonable ask.
  13. Jan 2, 2023 at 1:01 PM
    Azza2
    Yass
    AZ
    2021 TRD OR
    Yeah, it goes away when shift to 4hi. Forgot to mention it on the OP. Thank you.
    amyracecar[QUOTED] likes this.
  14. Jan 2, 2023 at 1:06 PM
    TacoSupremo19
    NJ
    I'm sorry but the dealer isn't going to do that. Definitely not a warranty issue.
    eurowner likes this.
  15. Jan 2, 2023 at 1:08 PM
    amyracecar
    Virginia Applejack
    SouthEast USA
    Get the ECGS needle bearing and convince the dealer to do the work [for free/under warranty] - as long as you remotely trust them.
    ECGS charged me 150$ to do the bearing/boot/diff fluid - for reference..
    My local shop looked up the labour and wanted to charge me like 500$ - said some nonsense about pulling the diff/blah/blah/blah - they are good but were unfamiliar with the issue/repair procedure, which made my decision simple.
