Needle Bearing vs. ECGS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AFS, Dec 21, 2022.
  1. Dec 22, 2022 at 9:51 AM
    #41
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Most differentials across manufacturers say 75w-90. Toyota is no different in that regard.
    Engine oils see the largest diversity across global regions but diff oil remains pretty constant.
    The front differential was never designed for a bushing nor 85w-140 so that needs to be taken into consideration when making your choice.
    As mentioned earlier the CV essentially floats in the bushing on a layer of oil but that layer only exists with viscosity it was engineered for.
  2. Nov 8, 2023 at 10:13 AM
    #42
    DirtTaco
    DirtTaco Well-Known Member
    What is the part number for seal that could possibly get damaged while changing the needle bearing out? I want to have one ready when I do the swap in case I damage it. 2020 trd sport premium
  3. Nov 8, 2023 at 10:20 AM
    #43
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    TnShooter and DirtTaco[QUOTED] like this.
  4. Nov 9, 2023 at 1:59 AM
    #44
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    ECGS recommends Dino (Non-Synthetic) 85w140 Lucas oil with a Ford or Dana limited slip additive for clutch style posi's.
    This is the reference that i have regarding 85/140 and ECGS.
    Did I miss something along the way?
    I have the bushing and use 75/90 in the front
    Have a mix of 80/90 and 85/140 in the rear. No issues. It’s all I could find down here. Rear is a bit quieter.
    Edit: I have around 56k miles on my bushing.
  5. Nov 9, 2023 at 4:52 AM
    #45
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    ECGS told me to run 85w140 dino in the front diff. I had the bushing in my 2nd gen for almost 60k before I sold the truck. No issues.
  6. Nov 9, 2023 at 6:17 AM
    #46
    DirtTaco
    Is the Toyota recommended oil bad for the bushing
  7. Nov 9, 2023 at 7:20 AM
    #47
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    No, spec oil is not bad for the bushing. ECGS has a post on their website with more on the subject.
    DirtTaco[QUOTED] likes this.
