Needle bearing wear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dub690, Nov 19, 2018.
  1. Nov 19, 2018 at 11:02 AM
    dub690
    dub690 [OP] Member
    2018 Tacoma Off Road
    3in leveling spacer
    I have a week to wait for my ECGS bearing replacement to get here, how much wear am I causing by driving the truck? Should I keep as many miles off of it while I wait or will not much happen in a weeks time?
  2. Nov 19, 2018 at 11:04 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    What happened? Is it making noise? Did you just lift? More info please
  3. Nov 19, 2018 at 11:08 AM
    dub690
    dub690 [OP] Member
    3in leveling spacer
    I put a leveling kit on the pickup about 6k miles ago and I’ve had a rotational vibration I’ve felt and heard for about a week now and most threads I’ve read it’s been The needle bearing so I ordered one and now waiting for it to get here. There is a small bit of play on my CV as well
  4. Nov 19, 2018 at 11:13 AM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    I dont think a needle bearing goes out that quickly, especially on a new truck. It might be driveline vibes from lifting the angles. Put the truck in 4wd and if the vibe goes away it's the needle bearing, if not you get to play the fun game of "what do I shim?"
  5. Nov 19, 2018 at 11:15 AM
    hyper15125
    NJ (609)
    If its not excessive I wouldnt worry about it. I drove mine for a while when the vibe arrived and there was no damage to anything when I installed the ECGS. I wouldnt drive cross country but normal local driving you should be fine.
  6. Nov 19, 2018 at 11:19 AM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    If you do a search someones needle bearing decided to shatter into pieces and that was an expensive fix and tedious to clean up if your a DIY’ed.
    Good luck.
  7. Nov 19, 2018 at 11:54 AM
    dub690
    dub690 [OP] Member
    3in leveling spacer
    Ok interesting, a few different ideas here. Thanks guys. I put the shins in to keep the diff stock so it wouldn’t change the angle of the driveline but nothing is ever perfect after altering it. I will try driving it around in 4H and see if the vibration persists or if it stops. Regardless I’ll have the bearing to put in anyway
  8. Nov 19, 2018 at 12:48 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I would recommend you don't drive around 24/7 in 4h, but rather find a straight road where you can get up to the speed of the vibrations and then throw it into 4h for a few to see if it goes away. *Generally*, you don't wanna stay in 4h on dry pavement unless you're going straight.
  9. Nov 19, 2018 at 12:50 PM
    dub690
    dub690 [OP] Member
    3in leveling spacer
    Yes agree, not what I meant by driving around lol can see how that looked bad. Thank you
