Needle Bearing - Yes, Replace It (ECGS)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by irritable_vowels, Apr 9, 2021.
  1. Sep 6, 2024 at 11:05 AM
    #441
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    Idk if there is a kit so to speak - just every option on the page when ordering the bushing.
    But yes - removal tool, bushing & seal installer and new axle seal.
    Edit - just saw I'm your neighbor. Thought about reaching out to local shops to do it (Bruno/Timbo) but I could be finishing up the work by the time I drop off the Tacoma.
    MyWyfsRnnr likes this.
  2. Sep 6, 2024 at 12:38 PM
    #442
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    @MyWyfsRnnr approximately how much fluid do you lose, when you pull the axle? I have a quart but, making sure I dont need more. Also, I am assuming it is way easier with the TRD skid plate off? Received the tools and parts this week. Thank you again for the help, answers, and video. Ski
  3. Sep 6, 2024 at 12:47 PM
    #443
    MyWyfsRnnr
    MyWyfsRnnr Well-Known Member
    Citrus Heights
    2018 4Runner TRD
    Prinsu full rack, 3" OME, 275/75/17 KO2, Anytime Backup, BudBuilt Skids & Sliders, Wet Okole covers, Tint front, Silverstar Headlights, black taillights, LED Backup lights, LED interior Lights
    1/2-3/4 quart if it is level is pretty typical.
    :hattip:
  4. Sep 6, 2024 at 4:38 PM
    #444
    skidooboy
    central lower mich
    Should be pretty good, I changed the fluid this spring, with Ravenol products. Should I plan on removing the TRD skid plate? Ski
    MyWyfsRnnr[QUOTED] likes this.
  5. Sep 6, 2024 at 9:14 PM
    #445
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Yes you can do it, easy really just take time. :thumbsup:
  6. Sep 6, 2024 at 11:47 PM
    #446
    MyWyfsRnnr
    Citrus Heights
    2018 4Runner TRD
    Yeah. It will make your clean up easier and not get gear oil on top of the skid that leaks out. It will also give you a better angle for getting the axle out
    skidooboy[QUOTED] likes this.
  7. Sep 7, 2024 at 8:25 AM
    #447
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    I have mine sitting in a box for when I install my 6112s and JBA UCAs :)
    I opted to buy the extra tools just so I don't have to try to jury rig something.
    Pixeltim likes this.
  8. Sep 8, 2024 at 8:18 PM
    #448
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Anyone have rubbing noise after installing their bushing? I did mine, taking my time and using the optional ecgs busing and seal installer tools, topping up the fluid till it stated to drip out.
    Things don't sound quite right though as it's making noise like a dry bearring when I spin the wheel by hand. I've already make sure it's not the brake caliper shield, although it's a similar noise to when a pebble gets lodged in that.
  9. Sep 9, 2024 at 5:33 AM
    #449
    MyWyfsRnnr
    Citrus Heights
    2018 4Runner TRD
    That's a new one to me. Let us know what you figure out. There is a coating on the bushing that should keep it from making noise even if it is totally dry (should lube it). One time when removing the wheel I tweaked the dust shield just enough to make a dragging sound. It didn't sound like the dust shield at all but I was able to figure it out over a beer.
  10. Sep 9, 2024 at 2:13 PM
    #450
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Figured it out! The caliper was just scrubbing the rotor, which I was able to isolate by having someone spin the tire while I listened closely, I then verified by pulling the brake pads and the noise going away. The differential makes a very subtle noise that sounds kind of like you were gently blowing on a pinwheel, but ecgs says that's very normal spider gear noise so all is well.
  11. Sep 11, 2024 at 8:45 PM
    #451
    Akguy
    Akguy Well-Known Member
    way up north
    23' Silver OR DCSB
    If you still have the tool kit I would love to borrow it for the weekend.
  12. Oct 14, 2024 at 11:38 AM
    #452
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    I am most likely going to have to do this in spring. Does the install tool stop at the correct depth? I thought I read somewhere that the clamshell needs to be install flush with the carrier.
    thomasburk likes this.
  13. Oct 14, 2024 at 12:25 PM
    #453
    Akguy
    way up north
    23' Silver OR DCSB
    If you use the driver from ecgs the bushing & the seal are stopped at the correct depth
  14. Oct 15, 2024 at 9:10 PM
    #454
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Yes, the tool will stop it flush with the outer lip.
    Be prepared to whack it hard though.
    xp0nex[QUOTED] and thomasburk like this.
  15. Oct 16, 2024 at 5:39 AM
    #455
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Yes, that was the surprising part of my bearing install, but after a careful inspection to confirm the bearing was flush, and straight away in-flight to its home, I was like, hell, whack it harder and firmer, and it kept sliding in there to home plate.
    xp0nex likes this.
  16. Oct 31, 2024 at 7:56 AM
    #456
    Mtaco14
    Mtaco14 Well-Known Member
    Nevada
    2023 TRD Off-Road
    I just ordered the ECGS bearing and seal for my '23 Taco. I can only assume one has to do an alignment when finished with the install.
  17. Oct 31, 2024 at 8:06 AM
    #457
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    No. None of the alignment fasteners will be loosened in your upcoming project.
  18. Oct 31, 2024 at 9:41 AM
    #458
    Mtaco14
    Nevada
    2023 TRD Off-Road
    Ok thanks, one more question. Does the diff lose a lot fluid while doing this bearing swap?
  19. Oct 31, 2024 at 10:03 AM
    #459
    Akguy
    way up north
    23' Silver OR DCSB
    Enough that you should refill what came out.
  20. Oct 31, 2024 at 10:09 AM
    #460
    Mtaco14
    Nevada
    2023 TRD Off-Road
    Ok thank you.
