Needle Bearing - Yes, Replace It (ECGS)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by irritable_vowels, Apr 9, 2021.
  1. May 10, 2025 at 6:20 PM
    #521
    Toyotas4Tots
    Toyotas4Tots Well-Known Member
    NC
    2023 Tacoma SR5
    I had the same thing happen when installing mine. I was square against the back of the bearing race and had to clearance the tool a little as well. I finally put a pry bar through the front yoke so it would stop rotating and the bearing came right out. Checked inside after removing it and no gouging.
  2. May 10, 2025 at 8:04 PM
    #522
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Hey, I see you got it out already, but yeah, I don't remember my front driveshaft spinning at all, maybe because I only had the driver front wheel off the ground, not the passenger wheel?
  3. May 10, 2025 at 9:03 PM
    #523
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Appreciate the follow up.
    When I tried inserting the tool the first time, it looked like there was enough space for the slight radius on the back side of the tool to fit and allow the puller to sit upright. But no, had to break out the grinder. Just hit the backside of each side of the tool, followed the radius and kept it even. Knocked the edges down with a file then cleaned it off with alcohol to make sure no swarf was on it. Then it popped right in. Held it uprihht with a flathead screwdriver while I threaded in the rod.
    I wiggled it all around once the all thread seemed to bottom out and snug up. Was working in the dark with a headlamp, so it was awkward trying to get the plate settled up even and square.
    I did jam a wrench into the yoke after the third time resetting it. I was then spinning the all thread and the puller, not pulling the needle bearing free.
    Finally got it completely squared up and it pulled the needle bearing right out. Have to wait till the morning to fill the diff and test drive, but I think this was the source of my front end intermittent vibration and sub-25mph front end noise. The needle bearing looks like it was worn down, the bearing surface on the cv shaft had a nice wear mark where the spacers between the needles looks like its been making contact.
  4. Jul 8, 2025 at 9:01 PM
    #524
    MACKT28
    MACKT28 Well-Known Member
    2006DCLB
    Heretic Ditch lights Toyo Open Countrys AT2 HI VIS OVERLAND RTT
    Curious if there is a need for doing both sides for the ecgs bushing or is it just the one side?
  5. Jul 8, 2025 at 9:03 PM
    #525
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Nope. There is only a needle bearing on the driver's side. The front diff is asymmetrical and the passenger side doesn't have one.
  6. Jul 8, 2025 at 9:07 PM
    #526
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    For the sake of install, only the left side. There is a second needle bearing on the other side of the carrier, but that’s deep in the differential assembly. The right axle shaft goes into an intermediate shaft which is a solid splined connection. That entire intermediate shaft end rides inside a strong ball bearing, so it’s an entirely different setup on that end.
  7. Jul 8, 2025 at 9:09 PM
    #527
    MACKT28
    2006DCLB
    Gotcha I took the truck and had some new bushings done on the upper control arm and the shop recommended I have the needle bearing taken out which I've had on my list but now I need to just get it and get it done.
    Bertw192[QUOTED] likes this.
  8. Jul 8, 2025 at 9:11 PM
    #528
    MACKT28
    2006DCLB
    That's what I thought on the driver side I wasn't 100% sure. Gonna order it up now.
  9. Jul 8, 2025 at 9:12 PM
    #529
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    It's good insurance. Some last forever, some fail immediately... but failure can result in diff destruction, so it's cheap insurance.
    Super easy DIY job.
    MyWyfsRnnr likes this.
