Needle Bearing - Yes, Replace It (ECGS)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by irritable_vowels, Apr 9, 2021.
  1. Feb 3, 2023 at 9:08 AM
    #161
    MyWyfsRnnr
    MyWyfsRnnr Well-Known Member
    Citrus Heights
    2018 4Runner TRD
    Prinsu full rack, 3" OME, 275/75/17 KO2, Anytime Backup, BudBuilt Skids & Sliders, Wet Okole covers, Tint front, Silverstar Headlights, black taillights, LED Backup lights, LED interior Lights
    @4xThad is correct, you can run it for a little while, you just want to do it soon. Basically, the longer you run it, the more damage to the cage that holds the needle bearings and the more likelihood that they will work themselves into the diff. Some people run them a long time without having it do that but just to be on the safe side order it and do it when you can, sooner than later. I wouldn't necessarily just stop driving it or anything.
  2. Feb 3, 2023 at 9:22 AM
    #162
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    Precisely. It took me 13 days after my lift, to find the time, have the parts and tools show up to to swap to the bushing. FWIW, I had 0 play in my drivers side CV but it was making hella noise and I could feel the vibration in the floorboards
  3. Feb 3, 2023 at 11:01 AM
    #163
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Original had 50k miles.
    ECGS bushing has like... 1k miles now? Working great.
  4. Feb 3, 2023 at 12:57 PM
    #164
    Rob64Taco
    Rob64Taco Well-Known Member
    Robbie
    2019 RedTacoma
    Wheels, grill ,fog lights ,blacked out emblems, hard cover shell
    Thank you
    how long did you know it was bad
  5. Feb 3, 2023 at 3:41 PM
    #165
    Bubba503
    Bubba503 Well-Known Member
    PNW
    2022 Tacoma TRD ORP Lunar Rock
    I must be deaf, I have had a TRD lift and 285s on my 2022 since it had like 600 miles on it, at 7k and haven’t heard or felt any weird vibrations. I’ll probably check the CVS and what not this weekend…
  6. Feb 3, 2023 at 4:03 PM
    #166
    MyWyfsRnnr
    Citrus Heights
    2018 4Runner TRD
    It is a hit and miss issue, some get it fast and some don't ever (yet) haha. You might not have a problem for a while. Just one of those things.
    4xThad likes this.
  7. Feb 3, 2023 at 10:53 PM
    #167
    HawkmanYota
    HawkmanYota Member
    David
    2017 Tacoma Double Cab TRD Sport 4WD
    Welcome to the Tacoma world! Not many weak links in them but this bearing is one. This should help...
    https://www.tacomaworld.com/threads...-and-write-up-to-follow.472081/#post-14248048
    MyWyfsRnnr likes this.
  8. Feb 4, 2023 at 7:44 AM
    #168
    MyWyfsRnnr
    Citrus Heights
    2018 4Runner TRD
    @HawkmanYota thanks for posting that link. That is one way. There are some tricks that speed it up, don't have to remove the axle from the hub. Here is my write up I posted on 4Runners:
    The way I do these:
    Pull fill plug first to make sure you can get gear oil back in before starting
    Pull ABS sensor wire
    Pull the brake hose mount bolt
    Pull caliper and wire everything to the side out of the way
    Pull lower ball joint bolts
    Pull tie rod end
    Pull bump stop
    Tap or pull the axle out and swing hub and disk assembly out and forward and slide the axle through the frame-lower control arm gap that you gained by removing the bump stop
    Then pull axle seal and needle bearing
    Install everything back opposite order.
    About 2 hours if you move efficiently and don't get into the beers to soon haha
  9. Feb 4, 2023 at 10:08 AM
    #169
    Rob64Taco
    Robbie
    2019 RedTacoma
    Would this be same with Tacoma
  10. Feb 4, 2023 at 10:35 AM
    #170
    MyWyfsRnnr
    Citrus Heights
    2018 4Runner TRD
    Yes, same diff. Same angles, almost identical suspension. Very subtle differences in sway bar, ball joint offset and tie rod ends I believe. FJ as well if I'm not mistaken
  11. Feb 7, 2023 at 7:57 PM
    #171
    Bubba503
    PNW
    Well, that being said...Does anyone know if there is a shop in the Portland area that will replace the bearing?
  12. Feb 7, 2023 at 8:31 PM
    #172
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    Da da da, anotha one bites the dust
  13. Feb 18, 2023 at 12:41 PM
    #173
    christianhle
    christianhle Member
    Does anyone know where I can get a needle bearing for my taco? I just lifted my truck two inches and I’m hearing a grinding noise. Thanks
  14. Feb 18, 2023 at 1:09 PM
    #174
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB
    https://eastcoastgearsupply.com/
    order by mail, shipping is prompt.
  15. Feb 18, 2023 at 1:10 PM
    #175
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB
    What state do you live in?
    Are you sure, the noise is nothing else?
  16. Feb 18, 2023 at 1:45 PM
    #176
    Rob64Taco
    Robbie
    2019 RedTacoma
    East coast gear supply
    christianhle[QUOTED] likes this.
  17. Feb 18, 2023 at 3:31 PM
    #177
    christianhle
    christianhle Member
    Dallas Texas. Not sure but I heard you should change them with a lift either way
    thomasburk[QUOTED] likes this.
  18. Feb 18, 2023 at 3:33 PM
    #178
    christianhle
    christianhle Member
  19. Feb 18, 2023 at 5:36 PM
    #179
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB
    Yes, they do, while the lift is going on, or soon thereafter.
  20. Feb 18, 2023 at 7:40 PM
    #180
    Rob64Taco
    Robbie
    2019 RedTacoma
    thomasburk likes this.
