Needle bearing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ozzyg812, Aug 6, 2019.
  1. Aug 6, 2019 at 10:52 AM
    ozzyg812
    ozzyg812 [OP] Member
    ozzy
    2018 White Tacoma TRD
    LED Head lights, LED pods and bumper light, OEM roof rack
    Im installing a 2" lift on my TRD Off Road, is a needle bearing replacement a must on a lift of this height or can i get away without replacing it?
  2. Aug 6, 2019 at 10:57 AM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    I did a 2” lift and did not replace needle bearing and have had no problems. I have read that others have had issues at 2”, so it may not be a single answer.
  3. Aug 6, 2019 at 10:58 AM
    SpeySquatch
    2016 TRD OR DCSB
    I would. I went thru 2 needle bearings before finally giving in to the ECGS bushing. Should have done it from the get go
    beergeek likes this.
  4. Aug 6, 2019 at 11:04 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I wouldn't touch it on a truck as new as yours. Just my opinion
    Inferno! likes this.
  5. Aug 6, 2019 at 11:09 AM
    ozzyg812
    ozzy
    Did you do a diff drop as well with your 2" lift?
  6. Aug 6, 2019 at 11:12 AM
    Inferno!
    El Dorado Hills
    No I did not. I read differing opinions on this too. I found that if you stick to 2” max lift, you don’t need either.
    SR-71A likes this.
  7. Aug 6, 2019 at 11:17 AM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    Don’t install it and you might have problems.
    Do install it and you won’t have problems.
    It’s cheap and not difficult to install, so why wouldn’t you?
    johnnyjunk, whatstcp and tacothyme like this.
  8. Aug 6, 2019 at 11:57 AM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    I went 2" and no vibes so far
