Needle bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Co971, Apr 8, 2025.
  1. Apr 8, 2025 at 3:46 PM
    Co971
    Co971 [OP] Member
    I've got the groaning noise coming from my left front differential. I changed my wheel bearing because it was bad so I know it's not that but when I put it in 4-wheel drive it doesn't change anything. Is it always the case that when you put it 4-wheel drive it should stop the noise if the needle bearing is the problem?
  2. Apr 8, 2025 at 5:01 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    That's my understanding. At the very least, it makes it noticeably better.
    If you're not getting any change in 4wd, my guess would be that it's something else.
    Are you lifted at all?
  3. Apr 8, 2025 at 5:11 PM
    Co971
    Co971 [OP] Member
    It's a 2013 lifted 2 1/2. I don't know what else it could be. I lifted it last Fall. Bilstein Coilovers,JBA UCA, new lower control arms, alignment, new tires. I'll probably go ahead and replace the needle bearing and hope for the best.
    winkel likes this.
  4. Apr 10, 2025 at 9:58 AM
    whits.taco
    whits.taco Member
    Boise, ID
    2013 Tacoma SR5
    Fox 2.0 IFP Coilovers Icon Tubular UCA’s CVJ High Angle CV boots Dobinson Leafs BAMF HD Hangers & Shackles Fox 2.0 IFP Shocks Wheeler’s U-bolt flip w/ Superbump 4.88 Yukon Gears Toyo 35x12.5 R/T’s Fuel Slayers 18x8.5 Bora 1” Spacers Flowmaster Super 10 Alpharex Headlights Baja Fogs Spyder Tails Ditch & chase lights Auxbeam Switch Pannel Midland MTX Kicker Sound System w/ 10” sub X-Bull 10000lb winch Plate Steel Front Bumper Tyger Rock Sliders DIY high clearance rear tube bumper
    Get under your truck and wiggle the cv axle... if you have more than 1/8" of play your needle bearing needs to be replaced. Also look for leaking diff oil. I would replace it with the ECGS clamshell bushing
  5. Apr 10, 2025 at 3:59 PM
    jeff7176
    jeff7176 Member
    On my 2015, the noise/vibration pretty much went away in 4HI. I swapped the needle bearing for the ECGS bushing and it's 100% now.
