NEEDS ADVICE: 2006 Tacoma Blown Engine
Discussion in 'Southern California' started by Albinomite, Aug 4, 2021.
  1. Aug 10, 2021 at 5:47 AM
    brwntms
    brwntms Well-Known Member
    Justin, have you found a seller yet or you plan on putting a new motor?
  2. Aug 10, 2021 at 7:14 AM
    Albinomite
    Albinomite [OP] Member
    Justin
    2006 Blue Toyota Tacoma 4WD 6cyl TRD Double Cab
    Sorry, it does look like I will be keeping the truck and getting a Jasper engine installed.
  3. Aug 10, 2021 at 10:45 AM
    brwntms
    That’s great to see. Best of luck with the new engine.
  4. Sep 17, 2021 at 1:48 PM
    goshawk5890
    goshawk5890 Member
    2010 Tacoma prerunner
    How's your truck running on the Jasper? Pretty much on the same boat
  5. Sep 17, 2021 at 2:34 PM
    Albinomite
    Justin
    Looks like it is running great. Still coming up to the first 500 miles since the install. Took a little time to get it, as they said it was an old model. Pretty sure as a 2006 it was a 2nd Gen, thought that doesn't seem that old to me in Toyota years!
    Go for it! It was a good option as the Tacoma redesign isn't out yet.
  6. Sep 23, 2021 at 4:31 PM
    bursthead
    bursthead Well-Known Member
    2019 Tacoma TRD Pro
    So sad to see another Tacoma with a head gasket failure. My 05 dc speedway blue 4.0 developed a head gasket leak. I was at 200k. It didnt blow the seal completely but it would overheat on long distance drives. Hopefully the new motor works out for you. I got quotes from 2k-5k for a replacement.
    Avoid any 05-06 early production motors. 07+ Fj motors were what was recommended to me.
  7. Oct 4, 2021 at 12:27 AM
    SEVtaco
    SEVtaco Well-Known Member
    Orange County
    2021 Tacoma TRD OR
    king2.5s/33s/Deaver/SCS wheels
    A little Late to the party, but the best bet what I offer my customers is getting a new bottom end from Toyota which as far as a couple of months ago was around 4-5k, machine the heads if possible, and do all front end service water pump, tensioners, etc all OEM because it is not worth it to tear the motor apart because of a crappy Chinese part. Had an FJ in we also did engine mounts, knock sensors(expensive), and was roughly 11-12k out the door. Personally never heard of Jasper, I'm guessing it's like LKQ, nice to see you ended up fixing the ol' 4.0 the market is crazy right now!
