Needs your ideas!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Feb 1, 2010.
  1. Feb 1, 2010 at 6:00 PM
    BSP4x4
    BSP4x4 [OP] Guest
    Looking for ways to attach this to a Grill craft...any creative ideas besides 3M tape or zip ties?
  2. Feb 1, 2010 at 6:24 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    drill the two sides for the clips,drill a center hole for the screw and take the gap out with washers.
  3. Feb 1, 2010 at 6:29 PM
    BSP4x4
    BSP4x4 [OP] Guest
    what do you mean by "take the gap out with washers?"
    I'd like to get it flush against the grill...
  4. Feb 1, 2010 at 6:32 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    i remember someone used a dremel to sand those things down. then used 3m double sided tape
  5. Feb 1, 2010 at 6:34 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    then you are gonna have to cut the ears off around the mounting points,theres four on each one
  6. Feb 1, 2010 at 6:38 PM
    BSP4x4
    BSP4x4 [OP] Guest
    are most satoshi grills with these type logos set up flush against the grill?
  7. Feb 1, 2010 at 6:41 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    or you could make each peg a threaded shaft with a dye and put three nuts on it.
  8. Feb 1, 2010 at 6:41 PM
    saltshaker
    saltshaker Well-Known Member
    johnny
    north carolina
    2011 TRD Off Road MGM AC
    AFE CAI, Fold-a-cover
    maybe you could grind that stuff off then epoxy some little bolts to the back and attach with washers and wingnuts
  9. Feb 1, 2010 at 6:47 PM
    BSP4x4
    BSP4x4 [OP] Guest
    best idea yet! maybe back that all up with 3m tape!
    are these logo's "hot items" i'd be pissed if some little f'er stole it!
  10. Feb 1, 2010 at 6:49 PM
    BSP4x4
    BSP4x4 [OP] Guest
    weould that require a special tool?
  11. Feb 1, 2010 at 6:54 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    just a thread dye,do you have a tap and dye set?if you thread the pegs it will be stronger .
  12. Feb 1, 2010 at 6:56 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
  13. Feb 1, 2010 at 7:05 PM
    Trigger
    Trigger Well-Known Member
  14. Feb 1, 2010 at 7:11 PM
    saltshaker
    johnny
    north carolina
    If you do go with that idea it would be smart to mark where to put the bolts or put the bolts in the grill first then put the epoxy on the bolts and stick the logo to the bolts cuz you don't want to get it all together and it not line up right with the holes in the grill and have to sit crooked.
    if you have a dye that may be easier if the pegs line up right and the pegs are long enough.
  15. Feb 1, 2010 at 7:19 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
  16. Feb 2, 2010 at 5:46 AM
    BSP4x4
    BSP4x4 [OP] Guest
    thanks guys!
  17. Feb 2, 2010 at 6:47 AM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    Mighty putty
  18. Feb 2, 2010 at 6:55 AM
    BSP4x4
    BSP4x4 [OP] Guest
    RIP : Billy Mays :(
  19. Feb 2, 2010 at 1:27 PM
    Chester
    Nor Cal
    Your meger attempts to make me mad or hurt my feelings is very lame at best.Everyone of your threads or questions is a drain on this forum......I would not get positive rep from others if it weren't ,aside the fact like I said before you can not make any decisions on your own nor can't seem to figure out much on your own.Now I try to be helpful with most people on here but you........you just make it to easy for me to tell it like it is,most on here are to nice to tell you that your retarded but I don't mind.Have a nice day I have a hospital to build
  20. Feb 2, 2010 at 1:33 PM
    BSP4x4
    BSP4x4 [OP] Guest
