Negative offset bearing noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SLVR4X4, Oct 24, 2022.
  1. Oct 24, 2022 at 4:41 PM
    SLVR4X4
    SLVR4X4 [OP] New Member
    SF Bay Area
    2007 Silver Dblcab 4x4 Sport
    5100s, 1" lift, -8mm wheels
    Immediately after installing some 17x9 wheels with -8mm offset I noticed a droning noise when driving. This wasn't present with factory wheels I had on just before, and I am using the same tires. Could the negative offsets add a force to push a worn bearing over the edge, or is there something else besides the hub bearings that I should check?
  2. Oct 25, 2022 at 12:18 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Go make sure all of the lug nuts are tight. Also make sure you have the proper type of lug nuts for the wheels.
    Alexely999 likes this.
  3. Oct 25, 2022 at 6:43 PM
    SLVR4X4
    SF Bay Area
    All lugs were torqued to 83 ft/lbs. Am using the appropriate acorn nuts for these wheels (does not require extended acorns).
