Negative offset
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jazdev2003, Jul 9, 2022.
  1. Jul 9, 2022 at 7:29 PM
    Jazdev2003
    Jazdev2003 [OP] New Member
    2020 Trd off-road
    My truck is lifted 2.5 inches. I want to go with a bigger negative offset without rubbing or having to cut anything. I will go 265 or 285 as long as it doesn’t rub and I don’t have to cut.. does anybody know the biggest negative offset I can go without rubbing?
  2. Jul 9, 2022 at 7:32 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    My wheels are -10 and I don’t have any rubbing. 265/75/16 tires.
    So you can do at least -10.
    Jazdev2003[OP] likes this.
  3. Jul 9, 2022 at 7:34 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Not sure but i can tell you spydertrax 1.5” spacers will make u rub
  4. Jul 9, 2022 at 7:34 PM
    Jazdev2003
    2020 Trd off-road
    Thank you I appreciate your input
    Road_Warrior likes this.
  5. Jul 9, 2022 at 7:36 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    265, 285, etc. denotes just the width of the tire, not diameter. Your truck came stock with 265/70-16 (31") tires. If you want to go with the popular 285/75-16 (33") size, some plastic trimming is usually needed no matter the offset; 0mm offset will require the least trimming (possibly no rubbing on the street). Anything more negative will require progressively more trimming. The biggest drawback to Toyotas (vs. Jeeps and Fords) is difficulty in fitting larger tires.
  6. Jul 9, 2022 at 7:58 PM
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    I have close to 2” lift up front(Eibach pro lift). 275/70/17 tires with -12 offset wheels. Rubbed the tiniest little bit on just one side. So minor that I could have left it alone but I easily fixed it with VERY minor trimming.
  7. Jul 9, 2022 at 9:22 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I rubbed pretty bad with stock suspension, 17x9 -12 wheels and 265/70/17 tires.
  8. Jul 10, 2022 at 4:32 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    You can actually calculate this yourself using a flat ruler pretty easily if you know the offset of your current wheel.
