Negatives of a 6 inch lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dragos, Jul 22, 2019.
  1. Jul 22, 2019 at 9:36 PM
    Dragos
    Dragos [OP] Member
    2019 TRD Offroad
    Hey so I was wondering what your guys opinions are running a 6 inch lift with 35s. Is this a dumb idea? Does it take away from the cars performance in trails and off roading? Would a 4 inch lift be better? Any info is helpful. Thanks in advance. I've had a small car my whole life so my knowledge is not very great.
    KTJO 4x4 likes this.
  2. Jul 22, 2019 at 9:43 PM
    tcjacado
    tcjacado Well-Known Member
    Do you want to cut into the truck?
    @KTJO 4x4 has a 6in lift on her truck.
    Click on the blue name and look for her build thread.
    Welcome to TW
  3. Jul 22, 2019 at 9:45 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    A 3” lift is better. You also need to regear with 35’s. Welcome to TW.
    Junkhead and Dragos[OP] like this.
  4. Jul 22, 2019 at 9:48 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Welcome to TW...6" lift?? I wouldn't, but You can do what you like.
    Big tall dave and Junkhead like this.
  5. Jul 22, 2019 at 9:53 PM
    Dragos
    Dragos [OP] Member
    2019 TRD Offroad
    No, I would definitely not want to cut into it. So if that's the case I will not consider it. Hey Matmo215 with the 3. You got pretty good clearance with 33s?
    tcjacado likes this.
  6. Jul 22, 2019 at 9:54 PM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    Lots of Hawaiian trucks with these bigger kits. I like the look but it’s not for me.
    Big tall dave likes this.
  7. Jul 22, 2019 at 10:00 PM
    tcjacado
    A 6 or 4 inch lift requires cutting the cross member out to drop the diff. Hence the name drop bracket lift.
    Also does not increase function of the truck.
    Stick to 2.5 inches on the lift and look for aftermarket control arms with adjustable caster. Then a good set of 33's (skinny ones not 285s) and the truck will handle just about anything
    MR E30, dfanonymous and Junkhead like this.
  8. Jul 22, 2019 at 10:01 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    After cutting the cab mount to fit my 33’s i have zero rub or any clearance issues at full flex
  9. Jul 22, 2019 at 10:01 PM
    tcjacado
    But you went with 285's right?
  10. Jul 22, 2019 at 10:03 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    Yeah, 285/75r16. Measures at 32.8” tall.
    tcjacado[QUOTED] likes this.
  11. Jul 22, 2019 at 10:09 PM
    tcjacado
    The 255/85/16 doesnt require cutting but I think mounted on the stock rim they may rub the uca, so wheel spacers are needed or a proper rim with correct back spacing to push it out.
    Junkhead and GillyLink like this.
  12. Jul 22, 2019 at 10:15 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    I run the -25mm SCS stealth 6’s
  13. Jul 22, 2019 at 10:28 PM
    KTJO 4x4
    KTJO 4x4 Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    I think personally this is a horrible conversation to have on here because you are going to get bashed. I personally say do what you want. It all depends on how hard you ride your truck, what purpose you have for your truck, etc. There are a ton of individuals that have cut their truck and their trucks are some of the best ones out there. Then there are some of those that have cut their trucks and they are some of the shittiest ones out there. Yes. I have cut my truck but I also think that I have have taken the time to do the research and have put together a great setup. I would never go back. I absolutely love my setup. I’m not a rock crawler tho. Could I rock crawl. Yes. However, when I went with this setup, that was not my plan. My biggest word of advice is have an idea of what you plan to do with your truck. I am running a 6” BDS with 35s and 18s. Feel free to check out my build and if you have any questions, let me know.
    GuacIsExtra, Ctupton, toku58 and 9 others like this.
  14. Jul 23, 2019 at 10:54 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    This is an excellent choice running this size tire with a choice lift. I have had the 6” lift, and the trucks road manners can get wonky, and then you spend stupid money on chasing issues, to only have twice what you should have in a good setup.
    In general, if you roll with a 6” lift and keep some of the stock suspension pieces, the truck will have no more flex than it did stock.
    My ‘12 had a 6” Fabtech and 35s, but it was not a real offroad truck (or rather I bought it that way and knew what it was). It satup so high it would get tippy, again unless you change out everything its not flexy at all.
    Let’s say for pure shits and giggles, you just want it for looks. I would still go with a nice ADS, King, Fox or Icon lift over a 6” diff drop lift.
    You will thank yourself later as the money you spend on a nice 2.5-3” lift will make your truck ride so much better.
    The 6” will still be a rougher ride.
    MattCowsmasher likes this.
  15. Jul 23, 2019 at 11:04 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    The downside is that Hawaiian men are constantly throwing their underwear at you
  16. Jul 23, 2019 at 11:04 AM
    tcjacado
    :rofl:
  17. Jul 23, 2019 at 11:14 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    If you need to park a lot in parking structures you may want to reconsider a tall lift. Some are really low.
  18. Jul 23, 2019 at 11:15 AM
    Built2Ride
    JB
    Southeast
    True, however if you have a hard time finding your car in parking lots. A 6” lift will surely make you stick out.
  19. Jul 23, 2019 at 11:18 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    The Aloha Bears are really getting aggressive these days!
  20. Jul 23, 2019 at 11:19 AM
    Gunshot-6A
    Conner
    Everett, WA
    My very forgetful friend has a mini cooper, and when we go to the big ikea or mall lot, she'll stop and get a red helium balloon and a long piece of string. :rofl:
