Nerf bar fitment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rohelio, Oct 9, 2015.
  1. Oct 9, 2015 at 5:05 PM
    rohelio
    rohelio [OP] Well-Known Member
    2016 Inferno DCSB OR
    Can any 3rd gen owners please confirm that 2015 nerf bars/running boards will fit the 2016?? Thanks in advance.
  2. Oct 9, 2015 at 9:45 PM
    Markc1024
    Markc1024 Well-Known Member
    I just installed the Go Rhino 5" OE Xtreme bars on mine. Fit perfect. What I liked about these is that some I looked at only used a single bolt to mount the front bracket to the vehicle. This one used 2 for each location. I got them in black composite.
    The Dude 80 and 8102 like this.
  3. Oct 10, 2015 at 6:23 AM
    rohelio
    Thank you very much for your reply. I am contemplating purchasing some predator style steps for my wife/family. I wouldn't really use the steps, but I am concerned with hitting the back of my leg every time I exit the vehicle. I often wear dress clothes for work. I don't want to buy them and have an issue.
  4. Oct 10, 2015 at 6:27 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    At stock height you wont need them. Maybe for your little ones. My GF is 4 10'' and she can manage to get in my lifted 2015, even though the 2016 sits about an inch higher than a stock 15 they still are relatively low to the ground, most fullsizes will be higher though, my two cents is to avoid it, it will rust, snag your clothes as you mentioned and makes a stock truck look smaller since it hangs. But if so I would avoid the OEM stuff as its simply NFAB parts. Look on NFAB, etc. then cross reference ebay for a better price if you do go the step route.
  5. Oct 10, 2015 at 1:02 PM
    Chaseus Episcopus
    Chaseus Episcopus Well-Known Member
    2016 BBP Tacoma Limited
  6. Oct 10, 2015 at 3:13 PM
    Markc1024
    Agreed that not really needed for in and out - actually need to step over it now. My purpose was more to prevent door dings and catch some of the stuff kicking up from the streets; although it will not stop it all.
    fatz likes this.
  7. Oct 10, 2015 at 3:45 PM
    rohelio
  8. Oct 11, 2015 at 4:16 AM
    Chaseus Episcopus
    It took a couple times in and out to get used to the position, but it's not in a bad spot after you get used to it. I dont need them to get in, but my wife will hopefully use them instead of doing the one cheek in and slide maneuver with the oh shit handle. I liked the look of these the most, and they really help when washing the top of the truck. I'll get some pics up soon. Im working 7 12s atm, and dont think about it when i get home... I need to hurry up and do this before the time change!
  9. Oct 11, 2015 at 4:18 PM
    The Dude 80
    The Dude 80 Well-Known Member
    OHIO
    2016 DCLB Sport 4X4
    Can you post some more pictures of your truck? I was convinced MGM was the way to go, but damn that white looks great!!
  10. Oct 11, 2015 at 8:24 PM
    fatz
    fatz Well-Known Member
    Ontario, Canadian
    2022 Trail
    255/75/17 Duratracs on FJ color matched steelies
    These are excellent bars. Is it just me or do they seem like they could be mounted a bit higher? Is this the way they look on 2nd gen or is it just the angle of the pic?
  11. Oct 11, 2015 at 8:28 PM
    MudsweatNgearz
    MudsweatNgearz Well-Known Member
    Arizona
    2016 DCSB TRD Sport Inferno & 2005 Sport DCLB 4X4 White
    The mounts are the same for 2nd gen and 3rd gen. I took my factory installed Predator steps off of my 16 and mounted them on my 05. Perfect match
  12. Oct 11, 2015 at 9:44 PM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    You get those Mud Flaps Stock? None of my dealers trucks have them. I want a set.
    I ordered ProZ 6" Premium Ovals in black from AutoAnything. Same reasons Door dings and protection.
  13. Oct 12, 2015 at 6:13 AM
    Markc1024
    Yes, OEM Mud Flaps that came on the truck. The Go Rhino's might be low for some, but it also seems the OEM ones sit kind of high. They do not drop below the underbody clearance.
  14. Oct 12, 2015 at 6:19 AM
    fatz
    Ontario, Canadian
    2022 Trail
    Thx Mark for the clarification and love the truck...exact one on order
  15. Oct 14, 2015 at 6:10 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Has anyone put on a bull bar yet?
