Nerf bars mounting locations on 2015 DCSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ejl923, Nov 14, 2014.
  1. Nov 14, 2014 at 7:57 AM
    ejl923
    ejl923 [OP] Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    Anybody have any idea whether the 2015 double cab has the same nerf/running board mounting locations and geometry. In other words, mfr's havent quite caught up to the 2015, so accessories are scarce. I want steps, but nothing fits the 2015, but 2014 options are abundant.
  2. Nov 14, 2014 at 8:04 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I would imagine everything is the same as the 2014, etc.
  3. Nov 14, 2014 at 8:28 AM
    ejl923
    Eric
    Western Mass
    i figured they would too, just looking for some actual application with it.
  4. Nov 14, 2014 at 9:35 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    If you have a nerf bar brand/product number in mind then I'd just call the vendor and double check. I've done this with other stuff that had a cut-off year of 2013 (i own a 2014) and they all said everything would fit fine.
  5. Nov 14, 2014 at 10:25 AM
    Mizzouborn
    Mizzouborn Well-Known Member
    Tampa, FL
    06 Tacoma PreRunner
    Thorley Headers Dual Exhaust Flowmaster 40s Bilstein Shocks/Struts K&N Air Filter
    I have nothing to go on but I'd bet a lot of money nothing has changed from my '06 to your '15 as far as mounting goes. You CAN find, let's say a 2010, and then get a tape measure, crawl underneath and then compare to your truck.
  6. Nov 14, 2014 at 10:31 AM
    heckeng
    heckeng Active Member
    I just installed some go rhino bars and they fit up just fine on my 15. I ordered for a 2014. As a side note, I am taking them off, they flex a considerable amount.
  7. Nov 14, 2014 at 10:34 AM
    ejl923
    Eric
    Western Mass
    are they the plastic ones?
  8. Nov 14, 2014 at 10:40 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'd say they should be the same since 2005.
  9. Nov 14, 2014 at 10:41 AM
    Mizzouborn
    Tampa, FL
    06 Tacoma PreRunner
    I have these http://www.rollingbigpower.com/steps-1/rx-3-steps-11.html and they don't flex a bit. Expensive yes but I think they're worth it. I got 20% off at AutoAnything so I paid $636.00.
  10. Nov 14, 2014 at 9:56 PM
    heckeng
    No, they were the stainless ones. I think the mounting brackets are where the flex is coming from. Instead of a 1 piece design, they are really two piece design for each bracket.
  11. Nov 15, 2014 at 6:12 AM
    ejl923
    Eric
    Western Mass
    Any recommendations then?
    I want nerfs, definitely looking for something bolt so no weld on sliders. i do mostly minor off roading, meaning established trails. The nerf bars are for looks, reaching the roof, and some slight protection from dings. Also want black in color. I think that would go with the black color of the truck.
