Nerf bars vs. Hi Lift jack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cnote4l, Feb 22, 2017.
  1. Feb 22, 2017 at 8:23 AM
    cnote4l
    cnote4l [OP] Gear Tech Customs Vendor
    Cody
    Evergreen, CO
    2016 TRD OR
    Does anybody know who would win in this fight?
    I got a 3" lift and don't want to encounter the day I need to hike up and change a tire and the stock jack won't help.
    Opinions? ...cost $.2 cents
  2. Feb 22, 2017 at 8:25 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Hi-lift would win... your nerf bars would bend I reckon... plus they're only mounted to the body which isn't a good structural point for lifting your truck.
    greeneggsnspam and DrFunker like this.
  3. Feb 22, 2017 at 8:26 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Bars lose. They will bend, your truck won't move an inch.
  4. Feb 22, 2017 at 8:28 AM
    User Name01
    Bolbi Stroganovsky
    Think up some lift points(sliders, bumper) or carry a piece of 6x6 around with you.
  5. Feb 22, 2017 at 8:28 AM
    Delmarva
    Tucson, AZ
    ^what he said
  6. Feb 22, 2017 at 8:29 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Your nerf bars will lose and damage the body of the truck.
    DrFunker likes this.
  7. Feb 22, 2017 at 8:49 AM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    I had a feelin nerf bars wouldn't stand a chance. I agree about the 6x6 tho my concern with that method is having to be on level ground
  8. Feb 22, 2017 at 8:51 AM
    Irongrave
    Irongrave Well-Known Member
    Drew
    Knoxville TN
    1998 T4R Limited
    Get a bottle jack. With a high lift you won't get the tires off the ground unless you strap the suspension.
  9. Feb 22, 2017 at 9:02 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    I have 3" lift in the back and about 2.5" in front. Change tires with factory bottle jack just fine. Just jack from the proper point and you'll be fine no matter how much lift or droop (hint: the axle and not the frame).
    la0d0g, GHOST SHIP and DrFunker like this.
  10. Feb 22, 2017 at 9:03 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Are you sure about that?
    I'm lifted and my 48" hi lift can get my front or rear wheels off the ground jacking from my sliders.
  11. Feb 22, 2017 at 9:09 AM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    The axle trick may work because the lower contact point ...depending on how long your suspension travels
  12. Feb 22, 2017 at 9:17 AM
    DVexile
    Ken
    It always works because it compresses your suspension. It isn't just the lower contact point - you are lifting from the unsprung point.
    Masshole_And_His_Taco likes this.
  13. Feb 22, 2017 at 9:24 AM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    Got you! From that point your compressing the suspension to get the tire up. Thanks for your 2 cents
    DVexile[QUOTED] likes this.
  14. Feb 22, 2017 at 10:12 AM
    Irongrave
    Drew
    Knoxville TN
    1998 T4R Limited
    And you are unloading the suspension on that side. Its fine for level ground but can get very sketchy on the trail.
    eccracer104[QUOTED] likes this.
  15. Feb 22, 2017 at 10:23 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Level ground myself, used it to lift the front wheels off the ground to change my brakes. 2nd gen prerunner with maxtrac spindles and coilovers ~ 5 or 6" of lift in the front.
    Have used it once on a 1st gen prerunner with solo spindles and coilovers, jacked off the front bumper for an emergency repair on the trail. Any trail use can be sketchy if you're on a hill or off camber. Best to try and move to flat ground not so much for jack length but more stability of the truck.
  16. Feb 22, 2017 at 12:43 PM
    cnote4l
    Cody
    Evergreen, CO
    2016 TRD OR
    @DVexile what size tires you runnin with your lift
  17. Feb 22, 2017 at 12:49 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Hehe, you are a funny guy.
  18. Feb 22, 2017 at 12:56 PM
    DVexile
    Ken
    I'm not being too aggressive in diameter and I like pizza cutters so just a LT235/85R16 which in the KO2 is a 31.7" diameter tire. Of course regardless of where you jack you'll need an extra 0.5" for each additional 1" of diameter over stock you go!
  19. Apr 8, 2017 at 5:38 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Gravity would actually win.
  20. Apr 8, 2017 at 6:39 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I have a 3" lift and used the factory bottle jack just a few weeks ago in the middle of a violent rain storm to change a rear tire and yah, I did get the job done but that was the day I started making plans for a Hi-lift and sliders.
    Silverspool and boogie3478 like this.
