Neutral Gear Faster Than Drive Gear
Discussion in 'Technical Chat' started by tim920, Nov 5, 2009.
  1. Nov 5, 2009 at 6:56 PM
    tim920
    tim920 [OP] Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    How come when I shift into N it is faster than D. This is of course letting go of the gas pedal and it's neither downhill or uphill. Is that a problem or is it suppose to be like that?:confused:
  2. Nov 5, 2009 at 6:57 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yes it is fine. Why are you putting it into N anyway?
  3. Nov 5, 2009 at 7:00 PM
    tim920
    Tim
    Boston, MA
    Let's say if I was coming to a red light, I would want to make it there without stepping on the gas. I figure it would sort preserve the gas. And also because I don't know how to drive a manual and it seems kind of cool. :D
  4. Nov 5, 2009 at 7:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not really good thing to do to an auto tranny.
  5. Nov 5, 2009 at 7:03 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    how come chris?
  6. Nov 5, 2009 at 7:06 PM
    tim920
    Tim
    Boston, MA
    Yeah I know that. Shifting into N wouldn't be a problem, right? But would it be any different if I come to a complete stop before I shift it back into drive?
  7. Nov 5, 2009 at 7:09 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Well, you can do whatever you want, but I don't really think It will save a lot of gas. Plus in some states it is illegal to shift into neutral gear when on the road but this is more for the big trucks more than anything.
    Some other people on this site do the same thing, but I don't think it is worth it.
  8. Nov 5, 2009 at 7:09 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    The coolant is pumped via the engine being in gear. Put it into N and the pump stops working, aka toasted engine/tranny.
    It slows down cause the engine has a bit of engine retardation.
  9. Nov 5, 2009 at 7:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Coasting with an auto tranny in Neutral can overheat the tranny. The engine drives the oil pump for the tranny, and by putting it in neutral, your cutting the oil supply to it, while its still being driven by the motion of the vehicle. Your better off leaving it in Drive when driving. Repetedly doing this could cause tranny to burn up.
  10. Nov 5, 2009 at 7:11 PM
    tim920
    Tim
    Boston, MA
    Holy crap! Thanks guys! I love this forum.
  11. Nov 5, 2009 at 7:14 PM
    08pretaco
    az
    so what about manuals coasting in neutral? does the pump keep going?
  12. Nov 5, 2009 at 7:16 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    since this is on the subject of gears... on my prerunner what is 4 3 2 L exactly used for i hear a lot of different things but never got a straight answer... and by the way i like this thread...
  13. Nov 5, 2009 at 7:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Used for manually shifting gears. 4 is 1 thru 4, 3 is 1 thru 3, etc. D is 1 thru 5.
  14. Nov 5, 2009 at 7:20 PM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    is there a general purpose used for them..?? I.E offroad, towing, uphill..?? or is just like the trip-tronic or whatever it is were its more useless than anything else..?? thanks for the info chris...
  15. Nov 5, 2009 at 7:20 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    They are used for going uphill or off roading. It will put the tranny into a lower gear, which will make it easier to go up the hill, giving the truck more torque.
  16. Nov 5, 2009 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont know....I shift manually when off road, or want more engine breaking. Somtimes when taking off quickly, I shift manually. Or when towing......
  17. Nov 5, 2009 at 7:23 PM
    copernicus
    copernicus Well-Known Member
    Engine breaking.
    (I think):drunk:
  18. Nov 5, 2009 at 7:24 PM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    There is no pump in manual transmissions (at least not in ones I've seen.) Fluid is moved around by the rotation of the gears/shafts.
  19. Nov 5, 2009 at 7:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Doesnt give any more torque...Just allows it to stay in the selected gear.
  20. Nov 5, 2009 at 7:29 PM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    coo... thanks for the info.. sorry for jacking the thread...
