Neutral Gear Faster Than Drive Gear
Discussion in 'Technical Chat' started by tim920, Nov 5, 2009.
  1. Nov 5, 2009 at 7:34 PM
    tim920
    tim920 [OP] Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    I HATE YOU!:quickdraw:
    :D Nah, I wanted to know, too. I think when we're in lower gear we take off faster but it doesn't give more torque like Chris said.
  2. Nov 5, 2009 at 7:34 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I must of wrote it wrong, are you saying the automatic wont shift when its in the 3 slot or 2L slot? When I go up hill and I put it into the 3rd slot (what I call a lower gear) it will shift, or at least I remember it shifting automatically. I don't use it that much in that gear.
    I would consider it giving the truck more "torque" or more of a mechanical advantage since it is in a lower gear, or what I consider a lower gear. It sure is a lot easier going up hill on the road, and seems like it has more torque over the 4D gear or slot. And I'm not saying more toque over the stock specs, just when going up hill versus the "higher gear" or 4D slot.
  3. Nov 5, 2009 at 7:35 PM
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    I never knew this about being in neutral. I didn't think it really did anything but I never would really do it because I just figured it would be bad.
  4. Nov 5, 2009 at 7:38 PM
    98tacoma27
    Ben
    Not Beech Creek
    ^^^ What he said.
    The auto tranny is basically a hydraulic unit. It contains clutch packs, valves and seals. Manuals are a gear box and can be sufficiently cooled with gear oil and ambient air..
  5. Nov 5, 2009 at 7:53 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    what about when used on trails.. or for me runnin thro the desert quick... lol
  6. Nov 5, 2009 at 7:59 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    If your going through the desert fast than you can keep it in D slot, or 3 slot. If your on trails going uphill than you can put it into the 2L slot or 3 slot. It all depends on how steep the road your going up. A lower number "or gear" for hill that is steeper.
  7. Nov 5, 2009 at 8:03 PM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    coo... thanks fellas appreciate the info... tim i hope u got something outta of it as well...
  8. Nov 5, 2009 at 8:09 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The reason the truck goes faster in neutral than in drive is because while in drive our trucks use the engine to brake while coasting. As far as downshifting into the lower gears with automatics, if your tranny is searching between drive and the next lower gear while going up a hill, then shift down a gear to avoid the tranny overheating. While offroading, I personally shift down into the lower gears going up steep hills, but switch back into drive or 4th gear as soon as possible. I mainly use the lower gears for engine breaking while going down hills on pavement and while off road instead of constantly useing the brakes. If the grade is really steep going down while offroad, I shift into 1st or 2nd gear and hit the down hill assist switch.
  9. Nov 5, 2009 at 8:16 PM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    ay is engine breaking bad..?? and what exactly is it doing..?? sorry for the newb questions lol
  10. Nov 5, 2009 at 8:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It will still shif, but, for example, if its in teh "3", it will shift up to 3rd gear. It wont go into 4th or 5th. If in the "2" position, it will shift from first to second, but no further. If in "L", it will stay in first gear.
  11. Nov 5, 2009 at 8:21 PM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    agree, former friend destroyed the transmission on a 99 Neon R/T sport, and on a 2007 Nissan Frontier SE 4X4 by messing with the gears like that on an auto tranny.
  12. Nov 5, 2009 at 8:22 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Well yeah because when your in the lower number slots "or gears" it is not needed to go fast so it wont shift into the higher gears.
  13. Nov 6, 2009 at 4:10 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Because you are coasting....
    Keeping it in Drive and you let off the gas, the resistance in the engine (engine braking) slows you down.
  14. Nov 7, 2009 at 9:06 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I live in the mountains and it's a 20min drive downhill to reach the city, lots of turns. I select '3' or '2' and use the engine to brake, if I didn't do this I would be changing pads every month. I don't see the need to select these gears when going uphill, I just give it more gas and the tranny downshifts.
  15. Nov 8, 2009 at 12:33 AM
    #35
    Clatrans243
    Clatrans243 Active Member
    Bill
    Albuquerque, NM
    2010 4X4 TRD Off Road
    Way back when, automatic transmissions had both a front oil pump and a rear oil pump, the rear one being driven by the output shaft, so coasting in Neutral wouldn't do any harm. The practice was known as "Hillbilly Overdrive", and many thought it improved fuel economy. In reality, though, it didn't save much gas at all, and it was illegal in most, if not all, states. As an aside, when slush boxes had rear oil pumps, it was possible to push start the car just like with a manual tranny as long as you could get it up to 30 mph before putting it in gear.
    I believe it was around the 60's or 70's when manufacturers quit putting rear oil pumps in their transmissions, and that's when coasting in neutral became a really bad idea. The engine is driving the front and only oil pump at idle speed, but the transmission parts, particularly the planetary gear sets, are turning at whatever speed the vehicle is traveling. Moreover, with the tranny being in neutral, transmission fluid isn't being routed to where it's needed for proper lubrication. It doesn't take much of that before things start binding up and coming apart.
    On the matter of gear selection with an automatic, I sure wish manufacturers would go back to single speed gearing in the lower gears. If, for example, you put the selector in "2", the tranny will still start out in 1st gear before shifting to 2nd. There are times, however, when it's better to start in a higher gear to prevent wheel spin. To my mind, "2" and "3" should be just that, 2nd and 3rd, with the shift sequence starting with 1st only in "4" and "D". I suspect, however, that I can only dream on that one.
  16. Nov 8, 2009 at 4:57 AM
    #36
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    Not a newb question at all IMO.
    Engine braking is generally good. What is happening is that when you take your foot off the gas, the engine no longer drives the wheels and instead the drive wheels can turn the engine. Above a certain RPM, the engine controls probably even turn the fuel off and you just have a big piston air pump. It takes work to pump and that slows the truck down. It is more noticeable on my Taco because the transmission control seems to be pretty aggressive about down shifting when coasting.
    This saves your brake linings. An extreme example is when towing or carrying heavy loads in hilly country. We were in WV this summer and following a Suburban towing a trailer over a pass. As soon as we got over, I could smell hot brake linings. Further down the hill, I saw smoke starting to come from the Suburban's wheel wells. Before we got to the bottom, smoke was billowing from the wheel wells.:eek: That driver was an idiot and should have shifted to a lower gear to let the engine provide some braking. He wasn't going that fast, but I dare not pass him because I had every expectation that his brakes would fail (they did not) and I did not want to be in front of him when that happened.
  17. Nov 8, 2009 at 6:34 AM
    #37
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    3 questions
    Could putting the engine in neutral for no more than like 3-6 seconds while coasting hurt much?
    What about putting the engine in neutral when stopped, say at a long red light? I wouldn't think it would do anything bad because the tranny isn't spinning right?
    I once read that manual shifting in the automatics is electronically controlled and won't go down the gear if it's going to over rev the engine, does this apply to not shifting upwards when necesarry the engine will automatically shift up to prevent damage or will it just ping off the limiter until you shift it up?
  18. Nov 8, 2009 at 6:44 AM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When moving keep the tranny in gear. May not damage anything imediatly, but it is hurting it none the less. Same with at a light, just leave it in drive. Putting it in neutral doent hurt when stopped, but if you have to get out of the way of something, you could forget to put it in drive, and not go when needed. Correct. The ECU will not select a speed when downshifting that would allow it to over rev.
  19. Nov 8, 2009 at 6:47 AM
    #39
    Jason'sLawnCare
    Thanks Chris
    I never thought about being in an emergency situation and then forgetting to do that in the heat of the moment.
  20. Nov 8, 2009 at 6:52 AM
    #40
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I just mentioned that, as it happened to me. :eek:
