Neutral safety switch problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seacraft23, Aug 6, 2024.
  1. Aug 6, 2024 at 7:41 AM
    seacraft23
    seacraft23 [OP] Member
    Working on my 2006 tacoma v6 automatic 4x4 I had to replace my neutral safety switch due to a non starting issue and a p0705 engine code. Getting the old one off was a struggle in the process it popped out of park a few times into neutral as I was prying against the old switch. I put the new switch on and I am having problems getting it adjusted. Only the N and R light up on the dash no matter how I try to adjust it. (All Dash lights were working before I swapped out the switch)
    Is it possible that shaft that turns was in the wrong position before i put the new switch on ?
    thanks for any info
  2. Aug 6, 2024 at 10:25 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I don't think it's possible to rotate the switch that far without breaking it.
    Did you verify there are no bent/broken/corroded pins in the connector and no broken wires near the plug?
  3. Aug 6, 2024 at 11:00 AM
    seacraft23
    The old one was broken came off in pieces
