Neutral safety switch Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cuttlefish, Feb 27, 2025.
  1. Feb 27, 2025 at 6:15 AM
    Cuttlefish
    Cuttlefish [OP] Member
    My 2013 Tacoma presented a code that led me to the Transmission neutral safety switch. Thankfully it is not too deeply hidden and I am able to reach the single bolt holding it on, HOWEVER, it seems the shaft that extends out of the transmission and through the switch itself will not let go of the switch preventing removal. The muffler prevents getting in or behind the switch to attempt a pry off. I have sprayed it with PB blaster (not a big fan) but still stuck.
    Can't get a hammer in there to tap on it. I was thinking about breaking it in order to remove it but if that doesn't work I will be dead in the water. At least now it still works (mostly).
    ANyone have a trick for getting this little electrical part off the transmission?
  2. Feb 27, 2025 at 6:16 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I’ve seen many of those stuck. I cut it with a Dremel, the switch, not the shaft.
    TnShooter and Too Stroked like this.
  3. Feb 27, 2025 at 6:26 AM
    Cuttlefish
    Yeah, I figured it would come to that. It is intermittent but working now so I hate to destroy a part that still allows the truck to function. If I can't get it off then I am stuck. I hate stress. Nothing is ever easy! I went to replace the rear bumper a few days ago. Was going to be a half hour job....until it wouldn't come off, then the receiver was rusted nd needed replacement, then the frame needed to be cleaned up painted, then the new bumper didn't fit, then the old brackets were bad and had to order new ones, then , then , then. A week later it is still sitting waiting for parts. I better go dig up the Dremel cutting bits.
  4. Feb 27, 2025 at 12:36 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Get the reinforced ones. They work better
  5. Feb 27, 2025 at 12:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Cut it off. 100% cut it off
    If you crank on the shaft coming out of the nut too much, you can damage the seal around the shaft and cause a leak.
    That seal is installed form INSIDE the transmission. The nut being stuck will have been the least of your problems if that happens.
    69 Jim, winkel, 1schoir and 1 other person like this.
  6. Mar 6, 2025 at 4:29 AM
    Cuttlefish
    Of course they did. Yeah, I am pretty careful when playing around in areas I am not familiar. I pulled as hard as I could without going crazy and backed off and decided I needed to think about this. The switch is intermittent now so I can use the truck. I have the new part, just have to figure out if I am going to cut it off or find another way. Your input is appreciated.
    TnShooter likes this.
  7. Mar 7, 2025 at 3:38 AM
    Cuttlefish
    Last week it was a reverse switch. The week before it was injectors. Before that rear sway bar bushings. Now rear bumper…. I love my truck and it has been great with little maintenance but it’s at the point where I’ve replaced virtually every switch and grommet on this thing. It’s almost new again.
  8. Mar 7, 2025 at 9:22 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    My lord. You had to do all that for a 2013 Tacoma?
    Jesus. All I've done to my 2012 is Oil/Filter Changes, Air/Cabin Filters, one set of tires, and an occasional wash/wax.
    ** Edit I need to add I had an AC Refrigerant leak I had repaired also...
  9. Mar 7, 2025 at 10:32 AM
    Cuttlefish
    No, no, no! It must have been the way I wrote the note. My 99 4Runner has had all of the replacements of little parts. The Tacoma is doing well, knock wood, with over 300k miles on it.
  10. Mar 7, 2025 at 11:24 AM
    el_smurfo
    el_smurfo Well-Known Member
    You've done as much as me and I have a 2007
    Jimmyh[QUOTED] likes this.
  11. Mar 7, 2025 at 11:28 AM
    Clearwater Bill
    Billy
    Largo Florida
    with all that description of rear bumper and appendages rust, have you carefully inspected the rest of the frame? Like in the places they fail from rust? Your neutral switch may be a mere blip in the big picture.
    Jimmyh likes this.
