Neutral safety switch?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yfz 450, Nov 16, 2014.
  1. Nov 16, 2014 at 4:29 PM
    Yfz 450
    Yfz 450 [OP] Well-Known Member
    Rockland ny
    tacoma 4x4
    I am not sure what years have them. I have a 98 and it is the first tacoma I have ever even been in, it has the neutral safty switch to the left of the steering wheel. My question is the truck will only start with that switch turned on whether the cultch is in or it's in neutral. Meaning I can only start my truck at all only when the switch is on. How can I fix thin incase one day that switch decideds to stop working
  2. Nov 16, 2014 at 4:36 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Not sure what your problem is? Sounds like the switch is doing its job. If it "stops working" bypass until a replacement can be installed.
  3. Nov 16, 2014 at 4:37 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    on autos the switch is on the shifter or sometimes on newer cars a second one is on the brake pedal and on manuals its on the clutch pedal. if it fails you replace it, that's all you can do, you don't ever want to "rig it" to start without it.
  4. Nov 16, 2014 at 5:38 PM
    Yfz 450
    Rockland ny
    tacoma 4x4
    Ok so everyone of these trucks you have to push that button to start it? I thought that it was just for if you wanted to start the truck in neutral with out the clutch pushed in. This truck will not start in neutral with clutch in or out or in gear with the clutch in unless the button is pushed
  5. Nov 16, 2014 at 7:32 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Sounds like the neutral switch on the clutch pedal is broken or disconnected.
  6. Nov 16, 2014 at 7:40 PM
    BamaToy1997
    Bill
    Navarre, FL
    The clutch safety switch on the clutch pedal has most likely gone bad. These trucks should all start just by pressing the clutch in. The switch is actually just really nice so that you can start your vehicle without sitting in the seat and depressing the clutch. So if it is ONLY starting from the switch on the dash, then the pedal switch is most likely bad.
  7. Nov 16, 2014 at 9:35 PM
    Yfz 450
    Rockland ny
    tacoma 4x4
    Is the peddle switch any easy and cheap fix? I'm a little low on funds
  8. Nov 17, 2014 at 8:47 AM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    it should be. Look up "pedal" switch or clutch safety switch on a parts site.
