Never change your differential fluid?!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nazareth7, Jul 16, 2023.
  1. Jul 17, 2023 at 2:40 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Many years ago I worked in a transmission shop we saved good clean trans fluid to put in owners cars that instead on changing the fluid with high mileage. The high detergent levels tended to wipe out any residue on the clutch plates (actually protecting them) and with out a few hundred miles they were walking.
  2. Jul 17, 2023 at 3:06 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Ive heard of that being done. I always wondered just how clean that high mileage fluid was.
  3. Jul 18, 2023 at 11:48 AM
    Nazareth7
    Nazareth7 [OP] Well-Known Member
    2007 Tacoma 2x4
    but my transmission is runs smooth and shifts amazing tho. Do I still need to worry about changing the fluid . Or don’t touch it ?
  4. Jul 18, 2023 at 1:49 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Personally I would leave it alone. If you are a normal driver not one to get your truck stuck, tow a good size camper or knee deep in water you'll probably grow tired of the truck before the transmission packs up.
    Williston likes this.
  5. Jul 18, 2023 at 3:41 PM
    Nazareth7
    2007 Tacoma 2x4
    Yea I don’t do any of the above. It’s my daily driver.
  6. Jul 18, 2023 at 4:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, you do need to change it.
    If changing the fluid causes an issue, you either changed the flushed wrong, or you already had an issue.
    Changing the fluid is NOT what causes issues. It just being a problem to your attention. (If there is one).
    Spend the money and do it. You’re about 100k over due.
    Then save (budget) $50 a year, and have it done again in 5/6 years.
    It will be even less if you do it yourself.
    BlkDakDave, Williston and jlemmond like this.
  7. Jul 19, 2023 at 11:20 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I'm not going to go into whether you should or shouldn't change it, that is up to you, but I think it would be worthwhile to at least check it to see if it's at the correct level. There have been some cases on this forum where people claimed the trans fluid has been low from the factory. In my first drain and fill only about 2.5 quarts came out. Later I did a flush and fill according to the procedure on the forum with Valvoline Max Life. If you're going to do a drain and fill I'd stick with Toyotas trans fluid.
  8. Jul 19, 2023 at 11:41 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Guys on the Tundras forum would be having a heart attack hearing about all of this "do not change transmission fluid" advice.
    wi_taco likes this.
  9. Jul 19, 2023 at 11:47 AM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    He asked whst he should do. He gets numerous suggestions saying change it and then he keeps asking the same question.
    He doesnt want to change it.
    End thread.
  10. Jul 19, 2023 at 11:51 AM
    sultan_of_sludge
    sultan_of_sludge Well-Known Member
    ZK
    2001 Tacoma TRD
    I do the diff before any big trip which ends up being about every 20k. I use a ScanGuage to monitor my trans temps. I drain and fill with fresh fluid based on how hot the trans has gotten even if it's "shifting fine." The hotter your fluid gets the more often you should change it. If I hit upwards of 280F I will change it within the week. I don't buy that "never change it" garbage.
    We buy these trucks to run.
    wi_taco and 2015WhiteOR like this.
  11. Jul 19, 2023 at 12:43 PM
    Nazareth7
    2007 Tacoma 2x4
    You sound stupid
    jlemmond[QUOTED] likes this.
  12. Jul 19, 2023 at 3:11 PM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    I tried to leave this alone but i couldnt. You asked a question on this forum for a reason. The assumption being that the members here had knowledge and expierience that you dont. Multiple people suggested you service both the diff fluid and trans fluid and gave you reasons that backed up there suggestions.
    And yet you still ask the question again. Just seems like your digging for any reason whatsoever to leave it alone. If thats your choice then do that, its your truck. Just dont waste peoples time asking questions to problems without any real desire to do anything about it.
    ZColorado, jackn7, Jaypown and 2 others like this.
  13. Dec 5, 2023 at 2:08 PM
    Mencose
    Mencose New Member
    2005 Tacoma 2WD
    Hello Everyone I've read over the comments as I have never changed my rear differential fluid or transmission fluid. First I appreciate all the comments and hope to get any additional comments if needed on my situation if needed. Please feel free share your input if you haven't already. I have a 2005 Tacoma 2WD LB that I purchased brand new. Currently with 266,000 miles and running good. Always changed the oil but never anything else. Look forward to any input.
  14. Dec 5, 2023 at 2:23 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Well if you didn’t worry about it for 187kmiles, I would shoot for another 100k.
    Hayden334, OffroadToy and Mencose like this.
  15. Dec 5, 2023 at 2:45 PM
    #35
    Mencose
    Mencose New Member
    2005 Tacoma 2WD
    Spitdog, funny cause I never thought about addressing it. Replaced front and rear complete suspension system and that's when I asked myself should I or do you change the differential fluid. I don't mind doing it just feel dumb that I didn't think to question it earlier.
  16. Dec 5, 2023 at 3:12 PM
    #36
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just do it all. Why wouldn't you?
    Mencose likes this.
  17. Dec 5, 2023 at 7:16 PM
    #37
    tyjoja
    tyjoja Well-Known Member
    Oregon
    2008 off road trd, Rugged Trail
    lift
    is it 4wd? and automatic i assume.... if 4wd you need to change both diffs and transfer case. I like using amsoil severe gear in the diffs and the automatic i would only use toyota oil only. youtube is your friend lots of great videos on draining and flushing tranny and how to change the diffs/tranfer case
  18. Dec 5, 2023 at 9:37 PM
    #38
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Just do the diff breather mod and run it up behind the rear brake light!
    jackn7 likes this.
  19. Dec 6, 2023 at 9:53 AM
    #39
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    never changed diff fluid on anything I owned and neither has my dad on his cars/vans
    wont hurt to change it
    Mencose likes this.
  20. Dec 6, 2023 at 11:41 AM
    #40
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    I doubt OP is coming back to this thread.
    Hayden334 and HondaGM like this.
