Never go 10,000 miles on Oil change! It will start burning oil!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gizmo6257, Sep 5, 2023.
  1. Sep 8, 2023 at 7:31 AM
    #221
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    And Bigfoot.
    Junkhead and tcjacado like this.
  2. Sep 8, 2023 at 7:34 AM
    #222
    golfindia
    Yes.
    pickup truck
    Ahhh sheeple.... Those Blackstone people are in cahoots with Toyota engineering dept to make you buy new tacomas sooner. "Proven fact".
    Steves104x4, willee51 and clg like this.
  3. Sep 8, 2023 at 7:34 AM
    #223
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    LOL... Nothing is "cheap" insurance if it is totally unnecessary.
    Look around. How many vehicles do you see on the road? How many of them break due to oiling issues? Not a lot. Not many at all. There are more vehicles that end up in the junkyard due to being worked on continuously than from neglect.
    But if it gives you comfort, the illusion of care and expense being useful, go for it. But don't tell me it's cheap insurance.
    SmoothTRD and MannyS like this.
  4. Sep 8, 2023 at 7:44 AM
    #224
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Not only are we creatures of habit, but it's hard to break old habits you learned as a youngster from your elders. Took me awhile to see there wasn't any difference worth writing home about in the quality of oil I had tested at 15k miles with synthetic vs 7.5k miles the manual recommended with dino oils for my 4.7 tundra. I never had any engine issue's owning that truck while pilling on nearly 300k miles on it. I guess some just like changing oil, far be it from me to spoil their fun. As far as 10k being good, or bad for these engines, idk either, only my experience with my 4.7, it was fine. I go by what the manual recommends, like our prius. Been doing 10k mile oil changes recommended since 2012 with 0w20. With well over 100k now it still runs the same as new. I can't foresee any problems as the tech that has changed it claims he has Prius's with over 250k with the same oil change intervals still running fine.
    SmoothTRD likes this.
  5. Sep 8, 2023 at 7:47 AM
    #225
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I used to work on a lot of those motors when I was in college; I found the motors which used "Pennsylvania Crude" based oil (you know, Pennzoil, Quaker State, Wolfs Head...), the engine would start burning oil due to the oil rings (and pretty much everything else in the engine) becoming sludged up with the paraffin wax which came from that type of oil, however, when I worked on an engine which had been fed a steady diet of mineral based oil (Valvoline and Havoline were the two most common), those engines ran hundreds of thousands of miles with no oil burning issues.
    zoo truck and bmg88201[QUOTED] like this.
  6. Sep 8, 2023 at 7:51 AM
    #226
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    For Pete's sake...
  7. Sep 8, 2023 at 7:58 AM
    #227
    Vmax540
    Chuck
    Clarion PA.
    Agree, I grew up in N.W. Pa. (the birth place of oil) and for years was fed a steady diet of Pa. crude as being the best, because of the high content of paraffin... sludge, nothing like it in the world !
  8. Sep 8, 2023 at 8:17 AM
    #228
    HMA
    HMA Well-Known Member
    Hal
    Bainbridge, Ga
    '10 Taco Surveying Machine '22 Lunar Rock
    I have a '10 Sport I bought new. Has 186,000 mi. now. Been doing oil changes once a year since new with Amsoil or Mobile 1EP. Mileage has varied from +-16,000 the first 10 years to +- 5,000 since. It has always used about a half a quart at the 6 month mark when I change the filter.
    I'm doing 5,000 on the '22.
    danny15l likes this.
  9. Sep 8, 2023 at 8:19 AM
    #229
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    wait....we get free filters? how?
  10. Sep 8, 2023 at 10:02 AM
    #230
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I'm right there with you honestly. Don't really care to throw money at something if its not needed. Truck doesn't burn or leak oil, rarely needs an air filter, only takes 3-4 pumps to purge new grease every time I lube driveline, shifts perfect, doesn't run hot, cranks every time, and stops when I want it to. I could spend thousands paying someone else to do "unneeded" things. When in reality, if you just take some time to truly look things over every now and then, it has pretty good chances to outlast you. What hurts the most is realizing you have more of a chance wrecking that perfectly maintained truck than you do having some costly catastrophic failure from maintenance negligence.
    Oil - 10k
    Air filters - as needed, not very often honestly
    Tires - 10k
    Driveline - 20-30k
    Trans - never
    Coolant - never
    Diffs/transfer - 60k
    Spark plugs - 100k
    PS/BF - never, unless replacing lines
    MAF - never
    Rear drums - 200-250k
    Front pads/rotors - 90-100k
    To top it off, this is gonna make someone on the internet really mad:
    detail/vacuum - 6 months-yearly
    wash - 6 months-yearly
    Travlr and zoo truck like this.
  11. Sep 8, 2023 at 11:13 AM
    #231
    zoo truck
    None
    I use to run those same dino oils in my cars, and trucks back in the 70's, and 80's...I saw the same results. Switched to castrol motor oil, and never had another similar issue.
    Horseshoez[QUOTED] likes this.
  12. Sep 8, 2023 at 11:17 AM
    #232
    zoo truck
    None
    Almost word for word I did on my gen1 tundra that gave me great service for 19 years. Now its someones else's truck.
  13. Sep 8, 2023 at 11:22 AM
    #233
    Horseshoez
    Dale
    Maryland
    Yeah, I forgot to list Castrol in my "good oil list". Sorry, my bad.
  14. Sep 8, 2023 at 2:33 PM
    #234
    tcjacado
    tcjacado Well-Known Member
    Chupacabra:fistbump::anonymous:
  15. Sep 8, 2023 at 2:40 PM
    #235
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I have trouble with your math.
    I’m not buying your used vehicle when there are better maintained others.
  16. Sep 8, 2023 at 2:41 PM
    #236
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    Oil change?
    tcjacado likes this.
  17. Sep 8, 2023 at 4:12 PM
    #237
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    I feel like everyone is just doing a copy/paste of their responses from other oil change threads.
  18. Sep 8, 2023 at 4:15 PM
    #238
    tcjacado
    Of course, cause there are 100's of them already. :anonymous: just like what is the biggest tire I can use/ run without rubbing :fistbump:
    e_engstro and Phlogiston[QUOTED] like this.
  19. Sep 8, 2023 at 4:41 PM
    #239
    Sonofliberty92
    Mark
    Maryland 4 South
    I change my oil every 50 thousand
  20. Sep 8, 2023 at 4:42 PM
    #240
    e_engstro
    e_engstro Well-Known Member
    Eric
    Arizona
    2019 Tacoma TRD Off-Road 4x2
    But if you change it at 9,999 miles you'll be fine
    SH10151 and TacoSR523 like this.
