Never used factory light harness not working, Trailer lights ok
Discussion in 'Towing' started by Rainmaker, Jun 15, 2018.
  1. Jun 15, 2018 at 4:30 PM
    Rainmaker
    Rainmaker [OP] Well-Known Member
    North California
    2019 Access Cab 4x4
    Hey all, I recently picked up a small travel trailer and when we hooked it up the trailer lights didn't work. We double checked with a different truck and confirmed that the trailer lights are functioning. It is the three prong harness and the one on my truck from the factory was zip tied to the frame. The fuses all seem to be good. Anyone else had this happen? If it was never used before is there a logical reason it would not be getting power to the trailer?
    Thanks for any help or suggestions!
  2. Jun 15, 2018 at 4:42 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Do you have a Volt Ohm meter? Trace the connections. If you don’t have a VOM then its hit or miss, clean the connections/contacts, try it again.
  3. Jun 15, 2018 at 6:40 PM
    Rainmaker
    North California
    2019 Access Cab 4x4
    We used a light tester to check the fuse panel and relay under the hood. All was good. Not getting anything at the trailer connection. Are there any other connections to check?
  4. Jun 16, 2018 at 4:32 AM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    Ground? And why was it zip tied? That leads me to think something major happened to it
  5. Jun 17, 2018 at 3:15 AM
    Indy
    Indy Master of all I survey.
    I don't think a zip tie was Toyotas approved method of equipment installation.
  6. Jun 20, 2018 at 11:38 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Do you have a aftermarket hitch on the truck?
    Maybe someone installed a hitch and wiring aftermarket and a splice is loose.
