New 1.25" Camburg UCA versus Older versus TC
Discussion in 'Suspension' started by Dr. Sleep, May 22, 2009.
  1. May 22, 2009 at 3:30 PM
    Dr. Sleep
    Dr. Sleep [OP] Well-Known Member
    Shane
    Colorado
    07 DoubleCab SR5 4X4
    I'm looking for anyone who has installed the newer Camburg UCAs with the 1.25" uniball.
    Quick questions:
    1. Do you know the length of the arm from mount to uniball cup (older design had about 7" whereas TC had 6.5")? Any change?
    2. If you have taken the vehicle to an alignment shop, was alignment a challenge (to factory settings)?
    3. What made you choose the newer Camburg UCAs over the TC?
  2. May 22, 2009 at 3:35 PM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    My order of these should be coming in anyday and I hope to have them installed next week. If you dont get a response I can update you next week.
    I ordered the whole CO setup. UCAs, and deavers/5100s for the back.
  3. May 22, 2009 at 7:50 PM
    Dr. Sleep
    Shane
    Colorado
    Thanks. I'd be especially interested if you could post a pic like the one attached. My guess is the Camburg UCAs still have this same measurement (7"), but some have suggested that at some point the welding jig at Camburg got misaligned and went from 6.5" to 7" and then back to 6.5" after they caught the error. I have no idea if there is any truth to this, but it would be nice to see a pic of their new UCA with the larger uniball, and recessed hardware with a tape measure up against it like in the pic to compare the old with the new.
  4. May 22, 2009 at 8:09 PM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    1. i am not sure on arm length
    2. my alignment is in specs my mechanic said it wasnt hart to get it \vs old stock arms
    3.they bigger uniball was the reason i choose the uca's the only problem is if i dont use teflon lube the uniball dies out and starts sqeekin like heck but other than that no complaints tough as nails here is pic
  5. May 22, 2009 at 8:20 PM
    Dr. Sleep
    Shane
    Colorado
    Thanks. How often do you have to apply that teflon lube? And where did you buy the teflon lube?
  6. May 22, 2009 at 8:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have always wondered why the Camburgs are so noisey. Everyone I know with TC's are nice and quiet.....
  7. May 22, 2009 at 9:01 PM
    cjag
    cjag Active Member
    Georgia
    07 TRD OFF Road 4x4
    www.cardomain.com/ride/2537226
  8. May 22, 2009 at 9:07 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    they do squeak but you dont hear it as much.
  9. May 22, 2009 at 10:12 PM
    straycat241
    paul
    i use fishline dry teflon lube i just apply some when it starts squeekin usually last a month or less if i do off roading and get them dusty so far other than that no complaints
  10. May 23, 2009 at 5:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  11. May 23, 2009 at 5:54 AM
    SilverSeven
    SilverSeven Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
  12. May 23, 2009 at 7:32 AM
    cjag
    cjag Active Member
    Georgia
    07 TRD OFF Road 4x4
    No problem. :thumbsup:
