NEW 16-23 Morimoto XB Evo Headlights are here!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by memario1214, Dec 19, 2024.
  1. Jan 15, 2025 at 7:07 PM
    #261
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    had that 55w setup in my 1st gen and its best performing headlight ive ran to this day.
  2. Jan 16, 2025 at 4:37 AM
    #262
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Plugged my diode dynamics ss3 max fogs back in. And I gotta say, those paired with the Evo's (which I purchased through TRS as an add-on with the headlights btw) AND with the supercharged drivers!? Freakin... glorious. My spot beam aux lights(ditch location) don't hardly make a dent at all now and are basically useless. :laugh:
    (I've actually got lots more to do to the truck too. Including more lights. Have a 30" 5d led bar for the lower valance I've yet to install. And I'll be getting something for my rago roof rack as well once that goes up.:alien::cool:)
  3. Jan 16, 2025 at 6:51 AM
    #263
    Yoshi I
    Yoshi I Well-Known Member
    Yoshi
    How high you are aiming SS3 Max fog? That's very high aim, much higher than low beam aim pointing upward acting as no hotspot wide high beam. It's just my occupational reaction, must advise make sure to use each light function when allowed and appropriate.
  4. Jan 16, 2025 at 12:28 PM
    #264
    NightProwler
    Harlan
    Maricopa, Az
    Yeah I haven't adjusted them yet. When I installed them I mounted them to be flush with the bumper and they are a little high. But the evos can probly be aimed a tad higher too. I adjusted those a little lower to play it safe and make small adjustments up as I continue to drive with them. Right now I'm using them with the high beams only with a Fleece all-lights-on module. But I do want to adjust them down and see how it performs to see if i can run them with low beams too. But even then, not sure I'd want to. They're insanely bright. Ha. They are SAE compliant tho.
  5. Jan 16, 2025 at 1:14 PM
    #265
    Yoshi I
    Yoshi
    I strongly suggest use lamp function correctly,
    Since you said you are using as high beam, below may not directly apply, but if you call it as fog and wish to use as fog
    1. SS3 Max fog is not SAE compliant fog beam, photometric test failed with several samples Just because label says so, does not mean actually is compliant. The reason of failure is due to cutoff not distinct enough = can't be aimed, test get rejected. many think Max is tight beam, but per photometric evaluation, it is still only half of required cutoff sharpness. Considered as not "visually aim-able"
    2. Even with SAE compliant fog beam, if not aimed per SAE definition, it cause severe glare that has no difference to wrongly aimed low beam or high beam in use.
    Word SAE fog only define beam has minimum characteristics allow to be used as fog lamp. Aiming is separate subject. Term SAE is label of minimum distribution character validation If not used per lamp function, it void any quality validation
    3. Fog beam only help when visibility is deeply bad, where low beam distance projection decay and only near field is visible range. Then fog beam help to illuminate ditch of the road.
    If you are considering to use SS3 Max as fog lamp
    It require 4~4.5 degree down aiming, since there is no visibly distinguish-able cutoff, only practical aiming way is to use "level-app" perhaps with your phone, use any flat referable front bezel edge of lamp, and tilt down lamp 4~4.5° downward. If any higher, it cause glare above SAE fog definition limit.
    At this aim, you will most likely only see top 1/3 of the beam on the road from driver view, and primary only see beam spread to immediate side angle ( this is the actual definition of fog function)
    4.5° down mean beam center to be 23.6' below lamp mount height at 25' wall. That is what is takes for SS3 max to be considered as glare free, fog application aim.
    Which makes cutoff equivalent to 4" below lamp height at 25' wall. and no excessive scatter above horizontal line to cause fog driving difficult.
    More detail about fog function shall be continued in J583 thread
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
    If you are strictly using as high beam, then it's up to you. You are seeing more because essentially you are using SS3 max as hotspot-less wide high beam overlay.
    But do not use this set up on the road with other drivers around. 100%, glare immensely blind on coming traffic driver.
    About aiming of XB Evo with SC driver, 2" down at 25' is essential. if fitted larger tires, wheels, or lifted, 3" down is needed. It's very high potent lamp. Must be carefully aimed. Aiming is not something you should do based on how it feels, it must be done with proper measurement. Because if affects other driver's safety.
    Enjoy lighting with solid understanding and responsibility, you can maximize benefit of design better that way.
    swils, K9tacoma and TRSAndrew like this.
  6. Jan 16, 2025 at 2:48 PM
    #266
    NightProwler
    Harlan
    Maricopa, Az
    Oh for sure! When I purchased the ss3's, I fully intended to use them with high beam supplemental lighting and offroading/ditch lighting. That's why I got the Fleece module to pair with it. Again I'll adjust them down with the proper measurement method and see how it looks, but I will most likely not like that and will keep them higher and use them as I planned to as previously stated.. My lift and 33's/34's will be going on in a couple weeks so I'm just waiting till thats all done and will make all the proper adjustments with the Evo's. :thumbsup:
  7. Jan 16, 2025 at 3:33 PM
    #267
    NightProwler
    Harlan
    Maricopa, Az
    I'll Also add to that, and say I'm not surprised the ss3 max's failed tests. There's no sharp cutoff and way too much spill (ie glare) for them to be classified as sae fog lights. I consider them to be offroad lights in the fog location. The sports or pros might be a better option in that case(haven't looked at those too closely). And to further add to it, I don't have a need for true fog lights where I live. We get fog maybe 2 or 3 days in the year and that's it. Some haboobs too during monsoon , might be beneficial to have amber fogs for that as well. But if I wanted true fog lights I probly would've went with the morimoto evos or d.d. elite's.
    Ok, back on topic.. waiting for someone to post this. Lol..
    :stayontopic:
    Where the heck is everyone else's Evo headlights at!?!? Get em installed and show em off already!!
    K9tacoma likes this.
  8. Jan 17, 2025 at 4:16 AM
    #268
    srSpencer
    srSpencer Member
    2021 magnetic gray SR 4x4
    Icon add a leaf, level kit, 33 inch tires falkin rubitrek
    so I am having the same problem, I got them for my SR. They’re sending me new resistors and but I just re-tapped into EFI number five because when I was in EFI number four, it blew the 10 amp fuse. I’m trying to figure out where I can tap it where it will work. I ended up putting a 20 amp with a 10 amp
  9. Jan 17, 2025 at 5:29 AM
    #269
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Have you tried the INJ fuse?
  10. Jan 17, 2025 at 9:08 AM
    #270
    srSpencer
    srSpencer Member
    Yeah it didn’t work I put a 20 in and moved it back to efi4 and it’s working
  11. Jan 17, 2025 at 9:09 AM
    #271
    Manta64
    Manta64 Well-Known Member
    Tony
    2016 Tacoma
    would like to change the front bumper- look on mine like the white Taco here..
  12. Jan 17, 2025 at 9:12 AM
    #272
    Manta64
    Tony
    2016 Tacoma
    drizzoh likes this.
  13. Jan 17, 2025 at 9:14 AM
    #273
    Manta64
    Tony
    2016 Tacoma
  14. Jan 17, 2025 at 9:14 AM
    #274
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Clean as hell. That's @ghostpro.la on IG.
  15. Jan 17, 2025 at 9:19 AM
    #275
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Finally got the RMA processed for my Gen2's <3.
    Now to figure out which ones they're going to send me and make sure it's the Evo's.
  16. Jan 17, 2025 at 10:28 AM
    #276
    TRSAndrew
    ATL
    Evos are the equivalent. Hybrids are a less expensive option.
    drizzoh[QUOTED] likes this.
  17. Jan 17, 2025 at 10:39 AM
    #277
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Yes. Hoping they don't try to send the Hybrids.
  18. Jan 18, 2025 at 9:14 AM
    #278
    Fortune Taco
    Fortune Taco Well-Known Member
    Mesa, AZ
    21 Tacoma Off Road 4x4
    I got my XB Evo’s installed and I drool every time I look at them. They did a killer job with the design and the light output is pretty damn good with the standard DOT led drivers installed.
    I also got the optional superchargers but I have not installed them yet.
  19. Jan 18, 2025 at 2:04 PM
    #279
    NightProwler
    Harlan
    Maricopa, Az
    Duuude sweet rig!!
    Superchargers are definitely worth it if you can spare the extra coin. At first it seems like they aren't much of an upgrade, until you flip the high beam on. Then you're like :eek:. That high beam increase is where it's at!
    Fortune Taco[QUOTED] likes this.
  20. Jan 18, 2025 at 2:33 PM
    #280
    devinzz1
    devin
    2023 aclb trd or mt
    going from stock halogens to these with superchargers is kinda funny
    swils, TSAVO, Fortune Taco and 3 others like this.
