NEW 16-23 Morimoto XB Evo Headlights are here!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by memario1214, Dec 19, 2024.
  1. Jan 4, 2025 at 9:25 AM
    #81
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Yeah as long as you see a huge drop in voltage like you mentioned, that indicates something is wrong with it.
    Very sorry for the issue regardless!
  2. Jan 5, 2025 at 8:01 AM
    #82
    TacomAlf
    TacomAlf New Member
    Josh
    St. Louis, MO
    2012 White Tacoma TX-Pro
    2.5" OME 885's, 1.5" AAL, Avid Light Bar, Avid Sliders, Shorty Antenna, TRD short throw shifter, AFE filter
    Do you have the hybrid model in stock as well right now or just the evo?
    usmc2msu likes this.
  3. Jan 6, 2025 at 5:10 PM
    #83
    lefty9206
    lefty9206 Well-Known Member
    Jarrod
    2021 gray TRD off road
    None yet
    Where did you get the stock fill plates if you don’t mind me asking. I’ve had the xb lights since 2020 and don’t have them either.
  4. Jan 6, 2025 at 7:24 PM
    #84
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    I replaced mine with some flat ones. You can have my OEM plates if you want. DM me
  5. Jan 6, 2025 at 8:25 PM
    #85
    370HSSSV
    370HSSSV Active Member
    Anyone know if these are coming for 2012-2015 trucks?
  6. Jan 7, 2025 at 3:11 AM
    #86
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    I got them from Meso Customs. I didnt really look around and I already knew about these so I ordered them.
    TRSAndrew likes this.
  7. Jan 7, 2025 at 9:50 AM
    #87
    TRSAndrew
    ATL
    It’s not on our list for this year, but I do think there will be a Gen 2 (not Evo) at some point.
    370HSSSV[QUOTED] likes this.
  8. Jan 7, 2025 at 9:51 AM
    #88
    TRSAndrew
    ATL
    The only ones I know of also. I intend to get some too if I go with another Taco next.
    SuperBad[QUOTED] likes this.
  9. Jan 7, 2025 at 2:37 PM
    #89
    HarcourtOrmand
    HarcourtOrmand Fmr 20 year ASE Master tech, now master of data.
    Justin
    Cherokee GA
    2023 Ice Cap TRD Pro
    CaliRaised Cat shields, OTT 9.0 Tune, TRD Intake, 4WP Rear bumper, Wireless AA, Morimoto Taillights, Morimoto Ditch lights, 4WP rock sliders, Interior noise reduction.
    Damn. Y'all used my truck to test the engineering samples for these 3 different times, I was hoping to get a set of them... Oh well.
    It's a shame Garrett was let go. He was pretty awesome.
  10. Jan 7, 2025 at 3:53 PM
    #90
    TRSAndrew
    ATL
    Was Garrett your point of contact for scheduling?
  11. Jan 7, 2025 at 4:45 PM
    #91
    HarcourtOrmand
    Justin
    Cherokee GA
    Yes he was. I sent him some contacts for an IT job like he was looking for but, haven't heard from him. Hope it worked out.
    Edit: Last time I picked up from yall was the day he was let go.
    TRSAndrew[QUOTED] likes this.
  12. Jan 8, 2025 at 9:47 AM
    #92
    TRSAndrew
    ATL
    R&D has definitely felt the impact of not having someone dedicated to vehicle procurement. :facepalm:
  13. Jan 8, 2025 at 9:50 AM
    #93
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Still no reply after multiple messages. Great support from Headlight Revolution :/
  14. Jan 8, 2025 at 9:55 AM
    #94
    HarcourtOrmand
    Justin
    Cherokee GA
    Oof. Yeah, you guys are welcome to use me anytime. Garrett said (before he was let go) that since I had been there 3x to test these, I'd get a set. I guess that went out the door with him.
  15. Jan 8, 2025 at 9:33 PM
    #95
    Buffs23
    Buffs23 Active Member
    White 2017 Toyota Tacoma TRD Offroad 4x4
    12volt Solutions Remote Start All LED interior lights 28% Solar FX window tint (legal limit)
    I installed these headlights on 1/3. Since then, I have kept an eye on my headlights to see if they are cycling on randomly. I decide to check the Ring Camera in my garage and noticed that last night at 12:20am the headlights turned on for a minute than turned back off. It also happened the night of 1/3 as well. Very weird! I have video proof of this from the two times my Ring Camera has caught it. I’m going to contact Morimoto about this and see what they say. I installed everything per Morimoto’s instructions.
    MGMDesertTaco likes this.
  16. Jan 8, 2025 at 9:36 PM
    #96
    Buffs23
    These headlights are amazing! I just wish there was an option to turn off DRL’s via selector column without having to unplug the fuse tap.
  17. Jan 8, 2025 at 9:46 PM
    #97
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Plug them in to the INJ fuse right next to the efi. They already said INJ fuse is fine and doesn't cycle with diagnostics like the efi does. Anything with power on with ignition should be good. There's at least one in the fuse location by drivers side footwell too that I use for my grille lights (which I had to do because there wasn't enough room to have both fuse taps right next to each other with the inj and efi anyways).
    I do find it a little odd that's the way it's designed. Maybe it's for compatibility for the sr5's without drls? I would also have liked them to be off on off. And have them at full brightness on drl mode, because as it is they dim down on drl mode. Also, the side marker leds are not on with the drls when in the off position.
  18. Jan 9, 2025 at 5:19 AM
    #98
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    Sorry, I tried to decipher this by reading previous posts, but still unsure. I have a 2017 SR5 with DRL option. Will these fit without having to tap into a fuse? The site reads as though the harness takes care of this issue. Thanks for any help.
  19. Jan 9, 2025 at 5:27 AM
    #99
    swils
    swils Well-Known Member
    Maryland
    2018 OR Blazing Blue, MT
    Having some headaches with my DIY set, and debating going with another full retrofit, or these. Anyone have them that's come from RX350/Bi-xenons?
    -Love the crisp cutoff on what I've got but understand this was a deliberate choice to soften that hard, blue top cutoff
    -I wish there was a trim option for all-black on the non-hybrid, but I could get over that.
    -Are the side markers just the little bulb slot, and no illumination with the full C-shaped reflector? I'd miss having my bright stage 2 meso side's, I'm all about making sure folks are aware I'm there on the road, and it's hard(er) to miss that big amber glow even from a direct blind spot
    -To that point, shame that the DRLs are only at half, if I understand right... Currently I almost always run in either DRLs-only or with headlights on, never auto or lights-off, and all controlled by the stalk. Am I understanding correctly that these can be run as High(+DRL), Low+DRL, DRL-at-50%, or Off? Can it be controlled by the stalk similarly?
    T-rev likes this.
  20. Jan 9, 2025 at 5:53 AM
    #100
    lefty9206
    Jarrod
    None yet
    Just received mine and the instructions I read have been updated to reflect the “inj” fuse tap location
