new 2010 taco srd
Discussion in 'Toyota Trucks & SUVs' started by mrdinh, Sep 8, 2010.
  1. Sep 8, 2010 at 4:33 AM
    mrdinh
    mrdinh [OP] Active Member
    TRD SR5
    westin nerf bars and argricover soft roll up bed cover
    i put my new lic plate on the back of the truck...but the bolts do not tighted..they just keep spinning...is that normal?..all my other vehicles tighted up...
    sup with this?
  2. Sep 8, 2010 at 4:37 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    really?.....i have no clue
  3. Sep 8, 2010 at 5:01 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Well you got the SRD version. I think that comes with spinning bolts right from the factory.
  4. Sep 8, 2010 at 5:38 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Might be stripped.
  5. Sep 8, 2010 at 8:01 AM
    mrdinh
    TRD SR5
    how do you fix the stripped holes?
  6. Sep 8, 2010 at 8:19 AM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    Use larger screws, or bolts.
  7. Sep 8, 2010 at 8:20 AM
    Pugga
    Massachusetts
    If it's just plastic, you can use a slightly larger bolt (not big enough where you'd crack the surrounding plastic though). If it's metal, re-tap the hole or use a self-tapping screw. You could also use a thru-bolt and a washer and nut at the back side or epoxy a nut to the backside of the hole.
    I'd look into the other response you got saying this is normal for the SRD package. I've never heard of this and don't want you to do a lot of work for nothing.
