new 2011 6-speed with squeaky clutch - normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by twoodcc, Sep 4, 2011.
  1. Sep 4, 2011 at 3:30 PM
    twoodcc
    twoodcc [OP] Well-Known Member
    Alabama
    2008 TRD Offroad Prerunner
    is a squeaky clutch on a brand new 2011 6-speed manual normal? is it something the dealer should fix?
    i've got a 2011 4x4 double cab 6-speed short bed with just under 5,000 miles. i was wondering if i should get the dealer to look at the clutch when i take it in for the first oil change (free).
    thanks
  2. Sep 4, 2011 at 3:44 PM
    2010tacoTRDOR6spd
    2010tacoTRDOR6spd Active Member
    Dave
    RI
    2010 Tacoma Access TRD-Off Road 4.0L 6spd
    I had the same issue come up with I think less that 5k on the truck. I brought it to the dealer and they did do a replacement of something (but it escaped me now).
    Bring it in and see what they say.
  3. Sep 4, 2011 at 3:51 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Same thing with mine. The lubed it up on my first visit, then I took it back for a second oil change and the guy replaced the bearing with new parts. What it comes down to is that the bearing is plastic, and plastic squeaks. So I'm fully expecting the new parts to squeak again.
    At this point, all I'm doing it trying to get a service history, so when I'm out of Warranty, I can go back to them and say "Hey, look at the service records. I've had this problem since day 1"
    The squeaky clutch itself doesn't bother me, I just turn up the radio.
  4. Sep 4, 2011 at 4:04 PM
    gbtoy4x4
    gbtoy4x4 Well-Known Member
    Greg
    Las Vegas
    2010 Silver TRD AC OR 4x4 6sp
    Factory Silver Sport Grill, Gray TRD Shift Knob, BFG 285/75/16 AT's, Debadged, AFE Cai, TRD Short Shifter, Redline Hood Struts, Leer Topper, Budbilt Front, Mid+Xcase Skids, ELocker Skid, Icon C/O, Built Right UCA's, Rear 2in AAL w/Bilstiens, AP U-Bolt flip, 1" 4Crawler Body Lift, Relentless Front Bumper w/Lights + Sliders, Rear Breather Mod, 5 ProComp 7089 Rims, AP SS Brake Lines, Famous Fab HC Rear Bumper W/Swing Out Tire Carrier, Synthetic Brake Fluid, Synthetic Power Steering Fluid, Front Superbumps, Hood Blackout,
    I believe there is a squeaky clutch pedal TSB
    I have the same squeak
  5. Sep 4, 2011 at 4:35 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    No reason not to have them look at it, as Ryan said, at least they will have record of you reporting it.
    Fink
  6. Sep 4, 2011 at 4:39 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    For some reason mine became less squeaky with time.
  7. Sep 4, 2011 at 9:43 PM
    twoodcc
    Alabama
    thanks guys. yeah i thought i'd have them look at it anyways. it seems that it's worse when the truck has been sitting for awhile, especially in the sun while i'm at work.
  8. Sep 4, 2011 at 9:46 PM
    Manwithoutaplan
    ID
    Yea it is normal, it just goes away afterwhile.
  9. Sep 5, 2011 at 10:25 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    if you look under your clutch pedal there is a metal rod that goes into a black plastic cylinder, at the top of the metal rod is a lug nut and attached the lug nut is a square piece of metal, twist that whole assembly to tighten it until you feel it "pop" into place, no more clutch squeak. no matter how many times the dealer replaces it, its not going to stop. my truck is a 2011 as well, and this is what fixed it.
    edit: i found a pic for ya, you can see the metal nut at the top of that rod, with the square attached to the top of it, dont tighten it too much, youll fell it click back into "place" or w/e then your clutch is good to go.... all the more reason to love these trucks haha
  10. Sep 5, 2011 at 10:28 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I have to do this every 3-5 months, but it works like a charm.
  11. Sep 12, 2011 at 6:48 PM
    twoodcc
    Alabama
    well i mentioned it when i took it in at 5,000 miles. they said they didn't find anything. it hasn't been as bad lately, but it hasn't been as hot either. (if the heat really has anything to do with it)
  12. Sep 12, 2011 at 6:53 PM
    Shiner
    Shiner BAMF
    Spencer
    Pensacola
    08 SWB 4x4 Sport 6-speed
    None yet, other than wheels :)
    ^This. You don't even need a wrench you can just hand turn it about a quarter turn. Quite possibly the easiest automotive fix ever.
