New 2013 Tacoma Transmission Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coreyward510, Apr 16, 2013.
  1. Apr 16, 2013 at 8:38 PM
    coreyward510
    coreyward510 [OP] Member
    Corey
    San Luis Obispo
    2013 4x4 V6 6spd
    Hey guys,
    I'm a new Tacoma owner and new to the site, so please excuse me if it takes a little while to figure out how this all works.
    I bought a 2013 Tacoma Access Cab, V6 6spd manual less than a week ago. After putting 400 miles on it (driving from the Bay Area to the Central Coast), the transmission has gone from smooth to very sticky. The shift from 1st to 2nd gear has become increasingly difficult and I don't know whether it may be a synchro problem or something else? Obviously I am still under warranty and have an appointment scheduled, but I was wondering if anyone could help me (or give me some peace of mind!)
    Thanks and I look forward to staying on this thread for years to come!
    Corey Ward
  2. Apr 17, 2013 at 5:07 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    That's one for the dealer mine got smother with use. How does the clutch pedal feel? any change there?
  3. Apr 17, 2013 at 5:37 PM
    coreyward510
    Corey
    San Luis Obispo
    2013 4x4 V6 6spd
    The clutch feels the same as it did before. Is it more likely a clutch or internal transmission problem? Here's to hoping that the dealer will have it figured out by tomorrow!
  4. Apr 17, 2013 at 5:40 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I hope they remembered to fill the tranny with fluid at the factory.
  5. Apr 17, 2013 at 6:56 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    That's strange. Definitely let your warranty help you on that one. I haven't had any problems with my 6 spd. Hope everything works out for you.
  6. Apr 18, 2013 at 9:52 PM
    coreyward510
    Corey
    San Luis Obispo
    2013 4x4 V6 6spd
    So I showed up this morning at the dealer hoping to resolve the issue. They had a mechanic take a 1 minute drive in the truck, in which he determined there was nothing wrong. He then offered to let me test drive another truck to give me some "peace of mind." Then, when they realized that they had no other 6spds, they told me there was nothing they could do. Some BS. I will NOT be returning to SLO Toyota, but rather Piercey where I bought it. Its a pretty shitty feeling having a brand new truck that is so uncomfortable to drive and no solution in sight...
  7. Apr 19, 2013 at 6:32 AM
    moondeath
    Pa, Gardners
    Definitely take it to your other dealer. If they give you a round of shit then open a claim with Toyota Corporate. They will open a case which will get things rolling towards a dealer looking further into your problem.
  8. May 21, 2013 at 4:28 PM
    skiomax
    skiomax Pro skier
    Ottawa, Ontario
    2013 Tacoma TDR Sport DC
    Extang cover Thule roof rack pop & Lock Short antena Weathertech floor liner TRD skid plate Leather Seat package
    I have the same issue with my new 2013, the dealer will now take the transmission off, and have a better look, they told me if its a transmission problem they would just replace it, it also could be the bearing in the drive shaft, or something wrong with the clutch... regardless they are taking care of the issue this week.
  9. May 21, 2013 at 5:53 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    i had the same issue. its starting to go away again on itself. almost 7000km
  10. May 21, 2013 at 8:05 PM
    Greytacoma1
    Greytacoma1 Senior Member
    dave
    Sacramento ca
    Tacoma dc lb
    Satoshi grill, Plasti derp, Ready lift kit, Wheelers 2 inch aal, Hella 700, Wheather tech floor mats, Blueinstinct armrest cover, sockmonkey bed decal, BHLM, debadge, 35% tint front windows, OEM roof rack, OEM step bar, TRD skid plate, tacomaworld.com decal, stock antenna trimed, gorilla extended lug nuts,diff breather mod, cab mount chop, AVS window visor, spidertrax 1.25 wheel spacers, toytec sway bar relocate, extra d ring mod
    Dam, your truck was probably built on a Friday. People were probably in a rush to get home. Anyways good luck and I hope they do find the problem. But I can almost predict that your probally not going to purchase a Toyota after this. Atleast that's how I would feel.
  11. May 21, 2013 at 8:37 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Shit man, good luck and keep us posted....
    I just bought a 6speed DCOR 2 week ago my self... So very interested on the outcome of this...
  12. May 22, 2013 at 4:18 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Good luck with any thing else. No such a thing as a perfect ride.
  13. May 22, 2013 at 10:25 AM
    Greytacoma1
    dave
    Sacramento ca
    Tacoma dc lb
    That's true, it's just how they handle problems. Put it to the back burner lately.
  14. May 22, 2013 at 10:35 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Absolutely go get the level checked out. If you have never owned a new manual transmission truck then hopefully this is just a learning curve.
    Peace of mind maybe: These Tacoma manuals feel much different then other vehicles. It's been 4 years and I still have tough time shifting from 1st to second with the 5 speed. I test drove a few 6 speeds and it was the same. Most people describe the feeling of being "notchy" and not very smooth.
    It will always be tougher to shift when the vehicle is not warmed up and even worse when it's cold out. Over time it should be a little looser as things wear in. It took 15,000 miles for mine to become smoother.
  15. May 22, 2013 at 10:47 AM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    my 2007 brand new 6 speed was so terrible shifting, I traded it on an auto, no complaints with it!
  16. May 22, 2013 at 8:42 PM
    skiomax
    skiomax Pro skier
    Ottawa, Ontario
    ya the shifting is horrible, this is my first manual truck but my 7th manual vehicle, never had issue shifting until i got a toyota. The dealership was pretty good about it, look like they will do everything to get this fix... will see next week once its actually in for repairs what they say
  17. May 23, 2013 at 5:14 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    No complaints at all with my 6 spd. Changed out the gear oil at 30K with synthetic made no difference at all shifted just as smooth as it did before.
  18. May 23, 2013 at 8:04 AM
    coreyward510
    Corey
    San Luis Obispo
    2013 4x4 V6 6spd
    Having only driven manual cars, I gave a few of my buddy'a 5 spd sticks a test drive. I realized that trucks in general are much notchier and you really don't have the quick shift ease as in cars. Once I realized this I finally had peace of mind and am fine with it now
  19. May 23, 2013 at 8:09 AM
    jassco
    NH
    2023 TRD Offroad
    Yeah it won't be like a car at all and you have to shift much slower (think dump truck). It will get a little smoother when everything wears a little. When you get to your 30k service try another fluid in there. I used Redline MT90 and it does help with the sticking a tiny bit. Any synthetic 75w-90 will do.
  20. May 23, 2013 at 8:14 AM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    I've just turned over 400 miles on mine and 1st to 2nd is a bit notchy too. All other gears shift fine. Curious to hear what they come up with.
