New 2013 Tacoma Transmission Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coreyward510, Apr 16, 2013.
  1. Aug 22, 2013 at 7:36 PM
    #41
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    How can you be a pro if I'm so much better than you?!
  2. Aug 23, 2013 at 5:02 AM
    #42
    RC4413
    RC4413 Well-Known Member
    2013 RC MGM 2.7 Manual 4x4
    Weathertech floor liners, Wet Okole seat covers, bed mat, Tinted windows, Dipped badges, AC drain extension, TRD skid, Avid sliders, Bilsteins 5100 x4 (front @ 1.75), TRD TT wheels, 265/75 16 Duratracs, OEM fogs and hitch.
    Good to hear! Hey, are you still having any issues from 1 to 2? Mine is doing the exact same thing you described, 1 to 2 is horrible.
  3. Aug 26, 2013 at 10:22 AM
    #43
    coreyward510
    coreyward510 [OP] Member
    Corey
    San Luis Obispo
    2013 4x4 V6 6spd
    Having originally posted this thread at less than 500 miles, I am now at 5,000 and I think that it has gotten smoother. Hopefully it continues to get better as some of you have said. I am looking at doing a tranny fluid change to a synthetic (anyone have any advice?)
  4. Aug 26, 2013 at 4:17 PM
    #44
    RC4413
    I have a scheduled appointment with the dealer tomorrow. Wish me luck!
  5. Aug 26, 2013 at 4:28 PM
    #45
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Redline MT-90.
  6. Aug 26, 2013 at 4:28 PM
    #46
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    MT90. The best thing ever for these.
  7. Aug 26, 2013 at 4:30 PM
    #47
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    The first thing I did to my 6 speed is switched tranny and t-case fluid to Redline. The notchiness gets smoother over time. Also lots have positive to say about getting short shift kit.
  8. Aug 26, 2013 at 5:24 PM
    #48
    Richc2048
    Richc2048 Well-Known Member
    Richard
    Aurora, Co
    O'13 DCSB TRD O/R
    It took me about 800 miles to figure out the 6 speed. I just had to realize my 2013 TRD OR 6 speed is not my old rx-7. Take it a little slower and its been doing better for me. Wait for the rpm to drop to the level of the next gear and now I'm golden. I'm not perfect on it yet but ill get there.
  9. Aug 26, 2013 at 5:41 PM
    #49
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Redline mt90
  10. Aug 26, 2013 at 5:46 PM
    #50
    RC4413
    Does anyone know what Toyota uses for their synthetics?
  11. Sep 17, 2013 at 7:39 AM
    #51
    Sprucetaco13
    Sprucetaco13 Well-Known Member
    Eric
    Staten Island, New York
    2016 TRD Sport Quicksand Tacoma
    I have a 2013 taco 2.7 4 cylinder with 5 speed. Every morning my clutch pedal squeaks for like the first 10-15 minutes of driving. It's super annoying and sometimes I feel like as I'm going into 1st gear that my slave has a air leak or something and the car jumps. Not sure if that's just me or its actually happening. I only have a little over 12k on my truck and this squeaky noise bothers the crap out of me. Anyone else have this?
  12. Sep 17, 2013 at 9:00 AM
    #52
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I test drove a 2009 manual once. At the time I was drving a 2006 Subaru STI.
    I was having a hard time shifting gears smoothly. The salesman in the passenger seat told me to shift at higher RPM's than what I was doing. I guess I was shifting too early at too low of an RPM.
    It made a big difference shifting at the higher RPM range...
    Just a thought!
  13. Sep 17, 2013 at 9:48 AM
    #53
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    You cannot push this transmission into first gear while moving in this truck. It has a lockout style shifter. That whine you hear is the synchro working overtime to match the gears up. This puts extra wear on the synchro. Come to a crawl or stop before shifting into first gear.
    The pedal creak has been there since the first gen's and the immediate patch has been to lube it with some lithium grease. Talk to your dealer and they should do this for you and the gas door as well as that will rust. They may replace the unit, but since the design is similar it will return as it did with mine. I just keep the spray can in my access cab lockers. It takes 5 seconds to do and lasts for a month or so. Good luck with it.
  14. Sep 17, 2013 at 12:14 PM
    #54
    Sprucetaco13
    Eric
    I never put the car into 1st while moving. This happens when the car is at a stop. It feels like a the clutch was disengaged too fast, even though I'm still holding the clutch partially. And also I understand the lubrication but why does it only squeak in the morning and stop after the car is warmed. If I sit in my car every morning and pump the clutch approx 20 times, the squeaky noise doesn't happen when driving.
  15. Sep 17, 2013 at 3:06 PM
    #55
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    And the gears are half the size and weight.
  16. Sep 17, 2013 at 3:17 PM
    #56
    jassco
    NH
    2023 TRD Offroad
    If you are referring to the catch point of this clutch then yeah we all would agree. There is no gradual grabbing it just catches at some point and if you don't have enough gas it will jerk and hop a lot. There was a TSB out for clutch issues so check with your dealer if you just aren't happy or things don't seem to feel right.
    For me the creek will happen loudly on very hot days in the summer or very cold days in the winter. After the car gets up to temp it tends to go away. Some of the parts are plastic and they make that noise when they dry out and expand/contract to a certain point to contact/rub the metal parts.
  17. Sep 17, 2013 at 6:53 PM
    #57
    woodchip
    woodchip Well-Known Member
    calgary,ab
    2013 taco 4x4 v6 manual
    firestone ride-rites
    have a 2013 and it shifts great.not like a car tranny but the best truck trans I have had.5 speed dodge was great too but low tow limit.the Taco shifts great,tows great,but it is a truck tranny.u will love it when the dealer fixes your issue.
  18. Nov 2, 2013 at 10:59 AM
    #58
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    I joined the site specifically to ask you this: Is the truck in your picture a 6 speed? I just traded in a 2013 trd sport access cab for a 2014 trd off road because I disliked the auto trans and needed the 4 doors to fit a car seat in back... I wanted a double cab long bed MANUAL trans but I was told by the dealership that the manual transmission was not available in that body configuration, regardless of trim package.
  19. Nov 3, 2013 at 8:15 AM
    #59
    dilligaff82
    New Hampshire
    Yep, that is correct. DCLB Off-Road (manual) was what I really wanted, but I was willing to settle for a DCLB Sport (manual) if it was available... I imagine it has something to do with that new carrier bearing set up they came out with a couple years ago that caused all those driveline vibration problems during acceleration.
  20. Nov 3, 2013 at 12:50 PM
    #60
    dilligaff82
    New Hampshire
    That could be true as well I suppose. It's unfortunate, but at least I'm only losing one foot of bed. I imagine it's going to be the last year for this body style, so I have to get it while the getting is good!
