New 2014 Tacoma interior rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bbumbles, Sep 9, 2014.
  1. Sep 9, 2014 at 4:32 PM
    bbumbles
    bbumbles [OP] Well-Known Member
    Bill
    MA
    2014 TRD Sport
    Stock
    I have a brand new 2014 and it has a annoying interior rattle seems like from passenger side. Not sure if its seat or seat belt or what.I tried everything I can think of so now I turn to you guys. Don't say take it to the dealer because they don't hear or fix rattles from my experience. My 2010 was basically the same truck and it never rattled in almost 100k. It just makes me mad everytime I drive I know I can turn the radio up but should I have to. Any help or tips would be great. Thanks!
  2. Sep 9, 2014 at 4:41 PM
    jbcanes
    jbcanes Well-Known Member
    Justin
    Tampa, FL
    14 PreRunner double cab
    backup camera, intermittent wiper, step bars, bug deflector, window vent, console vault,solid fold 2.0, 2016 sport wheels, front camera, anytime rear front camera mod, homelink mirror, dash cam, unifilter,
    I have the same problem on mine. Seems to be the passenger window. If I press on the seal in the upper right corner it seems to go away. Haven't found perminate solution.
  3. Sep 9, 2014 at 4:44 PM
    AZDesertTRD
    AZDesertTRD Well-Known Member
    Pamela
    Arizona
    2012 PreRunner Sport
    Take a look at your passenger seat, while it's empty, going down a slightly bumpy road. Mine shakes and rattles going down a paved street that's a little bumpy. The dealer replicated the issue, they reported to Toyota and they said to test a truck like mine and see if it does the same thing. It did. So Toyota said "it's normal." What????? Are they proud of it too? Second time they gave me this same answer on a different issue.
    I may try the other dealer in town and see what happens.
  4. Sep 9, 2014 at 4:56 PM
    bbumbles
    Bill
    MA
    2014 TRD Sport
    Stock
    Ya I say something like the seat is the problem don't hear it when someone is in the truck. What's weird is same seats in my old truck no noise. Probably will have to live with it I have had cars 10 years old with no rattle not happy I just know once a rattle it will always be there they are tough to find.
  5. Sep 9, 2014 at 5:11 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    So, it's not the belt buckle rattling against the interior trim?
    For shits and giggles I'd pull down the glove box door and make sure the cabin air filter (is even there) and that the filter door is closed.
    Check your front fenders are bolted on and secured tightly by placing your hand over the wheel opening and pushing forward and pulling back. Mine weren't and made an annoying bang every time I'd hit a bump.
  6. Sep 9, 2014 at 5:24 PM
    bbumbles
    Bill
    MA
    2014 TRD Sport
    Stock
    I checked the glove box everything checked out I will check the other thanks keep the ideas coming.
  7. Sep 9, 2014 at 5:28 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Mirror mount may be loose? Pry off the little black triangle and check the mirror mount bolts are tight?
  8. Sep 9, 2014 at 5:53 PM
    bbumbles
    Bill
    MA
    2014 TRD Sport
    Stock
    Done keep them coming!
  9. Sep 9, 2014 at 5:58 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Back to the glove box ... if you hold pressure on it does the noise go away?
    I am driving down U.S. 13 through the Carolinas one morning about 4:00 am ... all by myself ... damned if this rattle/noise would act up ... finally I held pressure on it (closed) and BAM ... no noise ... as the sun rose I stopped at the 1st small town Taylor Hardware I found and bought those 1/4" round rubber stick on guys ... mounted them in two corners and no noise.
  10. Sep 9, 2014 at 6:05 PM
    bbumbles
    Bill
    MA
    2014 TRD Sport
    Stock
    Interesting I will try that next time!
  11. Sep 9, 2014 at 7:00 PM
    DieselJunkie
    DieselJunkie Member
    I noticed the same problem in my new 2014 DC LB (TRD Sport). For me, it appeared to be the center console. However, to rectify the situation I added a supercharger which rattles even louder. :D
  12. Sep 9, 2014 at 7:05 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    My wife had sun glasses in the upper console, I could swear it was coming from the right but it was actually the damn sun glasses
  13. Sep 9, 2014 at 7:14 PM
    4lo
    4lo Well-Known Member
    El Campo, TX
    2017 TRD Sport
    some stuff
    I have three that come and go on my 13'. If the pass seat is in the perfect forward with lean position it hits the business end of the seatbelt in a way that makes it almost vibrate against the door. Also, the seat rattles when its in a specific slot..easy fix. Lastly, and most annoying, is a gasket squeak on the pass window that only happens on occasion, but it won't stop once it starts. Then it just goes away. Pandora works wonders as a fix.
  14. Sep 9, 2014 at 7:18 PM
    Roundarc
    Roundarc Born again Tacoma Owner
    Allan
    Virginia
    2025 TRD Sport Premium
    My front passenger seat belt will sometimes rattle against the B-pillar. The shoulder belt mount is adjustable and I lowered it and it improved things. Also the rear seat belts (in DC's) have clips to hold them against the C-pillar to keep them from rattling.
  15. Sep 9, 2014 at 8:24 PM
    luvium
    luvium Well-Known Member
    San Diego
    13 DCSB 4x4 TRD Offroad M.G
    Trimmed front flaps Extra D rings
    Try soundproofing the passenger door control cluster, mine was loose and rattled, a little thin weatherproofing strip on the inner edges and it was gone.
  16. Sep 9, 2014 at 8:50 PM
    1 Bored Clerk
    1 Bored Clerk Well-Known Member
    Vancouver, WA
    '13 4x4 AC TRD OR
    Look up the passenger seat headrest rattle thread. That could be your problem. I have the headrest issue with my 13.
  17. Sep 10, 2014 at 3:11 AM
    bbumbles
    Bill
    MA
    2014 TRD Sport
    Stock
    I say its the passenger seat they have some play. I think the whole back on both seats have play but since I am sitting in the drivers seat im sure it takes that away. I am going to look up seat rattle its not my first Toyota with seat issues my old camey use to POP there was a TSB so they fixed it. thanks
  18. Sep 10, 2014 at 3:28 AM
    mainetaco14
    mainetaco14 Member
    Maine
    2014 DCSB SR5
    Truxsport Tonneau, Front Window Tint, Weathertech Floor Mats, AVS Window Vent Visors
    I have a rattle in my dash that comes and goes. When I push down on dash it seems to go away. Anyone have this issue?
  19. Sep 10, 2014 at 6:45 AM
    rainmn
    rainmn Well-Known Member
    On my '13, the door seals on both front doors are making a noise that drives me insane. It actually sounds like a rattle, but I'm positive it's the door seals. On the passenger side, the paint is even wearing a little where the door seal contacts it in the upper corner.
    I've tried several different "fixes" so far, none of which have been very successful. Just ordered some Gummi Pfledge rubber care to try...I've seen where people have had some success with it on BMWs with the same issue. I'll find out tomorrow.
  20. Sep 10, 2014 at 1:17 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    I must be lucky. My 96 doesn't rattle whatsoever. *knock on wood*
