New 2015 truck 4x4 with 3400mi. Should lift it or not?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevo526, Aug 26, 2015.
  1. Aug 26, 2015 at 10:04 AM
    Kevo526
    Kevo526 [OP] Well-Known Member
    Kevin
    Camp Lejeune, NC
    2015 White Tacoma DCSB SR5 4x4
    Bilstein 5100, OME 885s, Deaver AAL, LR UCA, 17x9in black rhino sidewinders w/ BFG KO2 275/70/17, SOS Concepts sliders and rear bumper, Nfab light bar mount w/ 30in light bar.
    I just bought ome 885s with billstein 5100s, lr uca, and deaver aal and I'm beginning to rethink lifting my truck. The reason why I want to lift it is for camping on the beach where 4x4 is pretty much required. Sand can get really soft at PINS(padre island national seashore). Also increase my load in the rear. Not a big fan of my back end sagging when I go down there. I'm a very outdoorsy kind of guy. Should I do the lift and risk any warranties?
  2. Aug 26, 2015 at 10:06 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Seeing that you already paid for the lift I'd say go for it. I had a 3'' lift on my 2011 and the dealer did warranty work on it (driver side diff seal leak) no questions asked. Most dealers wont bother you unless your higher than 3'' and they still have to prove your lift caused the part failure per law. Your CVs will wear faster, your geometry will be different so possible vibes but my currently lifted 15 with 8k miles dosent have any and my 11 didn't either but every truck is different.
  3. Aug 26, 2015 at 10:19 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Go for it that's about how many miles I had on mine when it was lifted. It has very little effect on warranty it only effects parts that are directly related to the lift
  4. Aug 26, 2015 at 10:31 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  5. Aug 26, 2015 at 12:43 PM
    Kevo526
    Kevin
    Camp Lejeune, NC
    I plan on it depending how it looks with the AAL. I will still have my 265/65/17 so I don't want to go too high yet. Hopefully the front will only give 2.5in and 1.5 in the back. If it doesn't, I might start looking into bigger tires and new pack. As for my final decision, lift is going on this week! How long do yall think it will take to install with the coils and struts assembled and everything else with me and another guy? I've never done this before
    JimboAnz likes this.
  6. Aug 26, 2015 at 12:45 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    15 minutes per side.
    ODNAREM and ZachMX like this.
  7. Aug 26, 2015 at 12:49 PM
    ZachMX
    I've done it before so it was quick. But AAL and new coilovers and rear shocks and a few beer/shit stories, took us an hour or two. The worst will be lining up your leaf packs for the aal.
    ODNAREM likes this.
  8. Aug 26, 2015 at 12:51 PM
    T4RFTMFW
    AAL is a pain in the ass. FWIW, unless you're a circus midget there isn't room for 2 guys to install those parts unless you're doing both sides at once.
    Figure 30 minutes for the struts if you're following a DIY walk through and don't have any stuck bolts, and maybe an hour for the AALs.
    Double that if one guy watches the other guy work.
  9. Aug 26, 2015 at 12:54 PM
    ZachMX
    We each did a side, or one handed bolts, disassembled, etc. This was both our 2nd 2nd gen same lift so we knew how to do it quick and shnazzy.
    OP be careful of the centerpin not to strip the threads lining up the leafs.
  10. Aug 26, 2015 at 12:55 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
  11. Aug 26, 2015 at 12:55 PM
    Large
    Large Red
    Had my suspension ripped out in the driveway with 50 miles on the odo :anonymous:
  12. Aug 26, 2015 at 12:56 PM
    ZachMX
    Sell it on CL too, I got $150 for my struts and rear shocks. People crazy.
  13. Aug 26, 2015 at 12:56 PM
    T4RFTMFW
    First time AAL installs blow. :anonymous:
    Good advice on the centering pin threads.
  14. Aug 26, 2015 at 12:57 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I installed all the same components you listed recently, at 17K. I am an access cab, you are a double cab. I ended up nearly level with that, maybe a 1/2" rake. I then put in a 1" block in the rear and got my rake back where I like it. This pic is pre-1" block.
  15. Aug 26, 2015 at 12:59 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    :thumbsup: I also got $150 for the front OEM coils and shocks, local CL, and OEM UCAs fetched $50 to TW member
  16. Aug 26, 2015 at 1:06 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    I, like you, had never done anything like this before. I took it head on, solo. First AAL I struggeld with only because I could not get the shock nut off the top, ended up cutting it off. That was 3 hours on a thursday evening. Next morning, other AAL took maybe an hour. The got into the new UCAs and front shocks and coils. Mine were assembled also. Took maybe 6-7 hours for me to get the front done. lots of breaks with Ipad reviewing install videos and such. Tip---the long rear UCA bolt is a bitch to get out. Have to bend a little bit of metal and, it takes some coersion. When you get it through, leave it right there, stuck where it is, cuz u just gonna have to get it in through the new UCAs. :thumbsup: U can do it. to align the leaves after you open them up, have a long 1/4" socket extension to line up the holes, fits perfectly. Makes getting the new centering pin through a breeze.
    Kevo526[QUOTED][OP] likes this.
  17. Aug 26, 2015 at 1:14 PM
    Kevo526
    Kevin
    Camp Lejeune, NC
    Are yours 265/65/17? I might just do it today... My only problem is getting the alignment done, I'll have to drop it off tomorrow morning
    JimboAnz[QUOTED] likes this.
  18. Aug 26, 2015 at 1:18 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    I am still stock 265/70/16, same outside tire diameter though as the stock 17"s
    I had made an appointment for first thing sunday morning at my local firestone. they had it for 4 hours and did me well.
  19. Aug 26, 2015 at 1:20 PM
    Kevo526
    Kevin
    Camp Lejeune, NC
    Hmmm, I don't have a torque wrench too, ill pick one up at Lowe's thats by cobalt. Any complaints with the lift now?
  20. Aug 26, 2015 at 1:21 PM
    ZachMX
    Autozone rents tools like these, please dont buy a kobalt torque wrench!
