New 2018 Tacoma making clacking noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WaggishStone, Jan 15, 2018.
  1. Jan 15, 2018 at 8:46 PM
    WaggishStone
    WaggishStone [OP] Well-Known Member
    Joseph
    Toyota Tacoma 2018 TRD Off-Road Cement Gray
    I recently just bought a new 2018 Toyota Tacoma 4x4 OR. I started to notice that when I make a turn and go slow it makes a clacking noise toward the front of the vehicle (tie rods?) And I was wondering if something like this is 100% normal or if I should get it checked out by the dealer (assuming it’s free, since I just got it 3 weeks ago.) and I have not been doing any off roading (yet) like the average “taco” consumer. Thank you.
  2. Jan 15, 2018 at 8:49 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Take to dealer.
    Brand new trucks everything is warranted bumper to bumper.
    Jukeboxx13 and WaggishStone[OP] like this.
  3. Jan 15, 2018 at 8:50 PM
    WaggishStone
    Joseph
    Thank you.
  4. Jan 15, 2018 at 8:53 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... Take it to the dealer to have it checked and documented.
  5. Jan 15, 2018 at 8:53 PM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    Make sure you are in 2 wheel drive and not 4 wheel drive, before you take it to the dealership, or on the way to the dealership.
    Definately take it in regardless.
    Sometimes people get the knobs confused.
  6. Jan 15, 2018 at 8:59 PM
    WaggishStone
    Joseph
    Idk, I might leave it on because the truck will be climbing over the other vehicles in the lot to show my agony.
    InfernoTonka[QUOTED] likes this.
  7. Jan 15, 2018 at 10:00 PM
    dgirgis
    dgirgis Active Member
    2017 White SR5 Tacoma
    Not sure the purpose of this post, your warranty has just begun lol. But in regards to what the noise is coming from i'd try to have someone else stand outside while you're turning to see if they can pinpoint.
  8. Jan 15, 2018 at 11:03 PM
    WaggishStone
    Joseph
    Sorry, to clear it up I just was wondering if it was smart to get it checked out or if it was normal to experience this.
  9. Jan 15, 2018 at 11:05 PM
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    Have same truck at you OP, made a similiar thread a few days about same
    Issue. I plan on taking my truck in soon for its first oil change and will that looked at as well.
    WaggishStone[OP] likes this.
  10. Jan 15, 2018 at 11:26 PM
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    When you tap the brakes?
  11. Jan 15, 2018 at 11:40 PM
    WaggishStone
    Joseph
    No, I don’t even have to touch the brake pedal. It’s when it accelerates or at a steady pace.
  12. Jan 15, 2018 at 11:44 PM
    GR8APE
    GR8APE Well-Known Member
    It's possible that the rear differential is low of lube.
    InfernoTonka likes this.
  13. Jan 16, 2018 at 12:35 AM
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    2016 Tacoma here. I had this problem since the day I bought my truck. It happens I when you take turns, usually onto a drive way ramp and happens whether I turn left or right. It's like a
    TRRRK....TRRKKKK sound, like gears grinding. I've taken my truck to the dealership more than 2 occasions about this, and they agree the problem exists, grease whatever they think the issue is, but always comes back after a while... I've given up taking it to them, and now just live with it. No lift or anything.
  14. Jan 16, 2018 at 1:11 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Wow. You have it on 4wd ? That's the problem . Only use 4wd on the trails not on concrete.
  15. Jan 16, 2018 at 4:58 AM
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    My old F-150 did something similar, It was the wheel bearing from the side it ticked. Not saying that’s what your problem is, just food for thought. Either way take it to the dealership and report back their findings, could help other members :hattip:
  16. Jan 16, 2018 at 3:14 PM
    GR8APE
    I once had a 2007 Tacoma that also made a noise similar to what you describe, it had a limited slip differential. I drained all the fluid and replaced it and added a few ounces of limited slip additive . I drove it in an empty parking lot in a figure 8 a few times and never heard the noise again. It might be worth a try .
  17. Jan 20, 2018 at 3:03 PM
    WaggishStone
    Joseph
    So just went into Toyota to check it out and it made the noise much less noticeable. I hear it very faintly but what they did was lubricated the steering stops. Hope this helps someone.
  18. Jan 20, 2018 at 3:47 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    That worked on your 07 because you had an actual mechanical limited slip rear, today it is brake operated limited slip.
  19. Jan 23, 2018 at 7:07 PM
    orangeracer
    I still haven't taken mine to the dealer, when I called to make an appointment they had nothing that fit my schedule this week. Will probably take it next week. I heard the noise again today though. Where are steering stops located? Taking a wild guess, it sounds like my clank/grind noise is coming from the undercarriage area about 2-3' in front the steering wheel and around the drivers side engine/frame area.
  20. Jan 26, 2018 at 10:44 AM
    WaggishStone
    Joseph
    I don’t know where it is located but I’m about to take mine in again as well because the noise is still prominent.
